Annoying Check Lights
  • Purdue89E30
    • 991
    I get the wiper fluid and brake light warnings all the time and I know there is nothing wrong with either. My wiper fluid is topped off and the light comes on every time I take a sharp turn. The brake light warning comes on and goes off at random times. Anybody know how to fix this? Thanks
    "One of my top five favorite, like, cool...nerd cars"
    '89 325i-sold
    '98 528i
  • kylebes1
    • May 2004
    • 2804
    wish i had a wiper fluid level light. :)
    • Spencer
      • 767
      My eta did the exact same thing. The only fix I found was selling the car :-)
      -Spencer
      • parkerbink
        • Jun 2004
        • 10138
        The sensors are messed up, both on my car are floats, make sure they have a free range of movement & aren't sticking.
        • Digitalwave
          is a poseur
          • 6299
          It's the sensors on both. There is a sensor for the washer right on the tank, and the driver's side front and passenger side rear calipers house the brake lining sensors.
          RISING EDGE
          • e304lyfe
            • 807
            jump the wire on the washer tank sensor, its a useless sensor.
            • Mystikal
              Wheel Fitment Expert
              • 9602
              I use mine as a G meter, when I hit an on-ramp just right the light comes on as I power from the apex.
              • spencers
                • Jan 2004
                • 1150
                Same here, except mine is the coolant light. lol.. And there's coolant in the damn thing!
                • dgspikes
                  • Mar 2004
                  • 179
                  mine goes on every time i turn the car on for the brake lights. its from when a bulb was out, but after i replaced it, it still goes on. once i touch the brake it will go off. how do i get rid of it.
                  • Mystikal
                    • 9602
                    LOL, just messin with ya. It's normal, it doesn't know if they're working until you press the pedal, obviously.
                    • dgspikes
                      • Mar 2004
                      • 179
                      haha, no, im not that new, its been like that for the past 2 years of having the car. it does that for everyone?
                      • dgspikes
                        • Mar 2004
                        • 179
                        if that is true that everyones does that, have any of you tried to see how far you can go without using you brakes?
                        • rwh11385
                          lance_entities
                          • 18403
                          Re: Annoying Check Lights
                          yeah, my wiper fluid check light is a bitch......and the sensor is probably bad as it came on with it topped off constantly......not it is once in a while. but annoying.
                          you going to the BMWCCP tonight?
                          • James Crivellone
                            Head Janitor
                            • 6305
                            my record is 10 miles, from my parents house to mine
                            without brakes
                            lots of downshifting :-D
                            • 318daily
                              • 507
                              If all your brake lights function correctly then I would guess it is the brake light switch (sometimes referred to as the Stop LIght Switch). A new one will run around $12
                              from bimmerzone.com
                              The switch is located behind the brake pedal.
