‘87 325is - Does your fuel pump make noise before you start the car?
  • mach schnell
    • Apr 2008
    • 1059
    In an ‘87 325is, with the early fuel pump system - does your fuel pump whine (as in, it’s working properly) when you turn the key almost all the way, before you start the car?
  • digger
    • Nov 2005
    • 6196
    mine with late single in tank did not run with igntion on (even for a short time), had to be cranking
    • dnguyen1963
      • Nov 2011
      • 2651
      I think the pump turns on for a brief 2 sec then off until you crank the engine.
      • mach schnell
        • Apr 2008
        • 1059
        Mine does not make any noise at all. And my car won’t start. So I am wondering if it’s the pump having failed.
        • dnguyen1963
          dnguyen1963 commented
          Editing a comment
          Disconnect the fuel line going into the fuel rail. Put it into a container then start the car. If fuel is shooting out then your fuel pump is operational.
      • digger
        • Nov 2005
        • 6196
        jump it at the relay to see if it runs you will hear it. then you can check it runs when it is cranking as above.
        • jbontke
          • Mar 2019
          • 449
          The fuel pump will not make noise or "prime" before the car starts. It only when when the engine is cranking or running. I have tested this and know I am correct.
