M20 AC conversion to R134a - Is new Aux fan necessary?
  • Hoffbrohaus
    • Sep 2013
    • 519
    I'm planning out my AC conversion (90 325is) and it looks like I have to do the Sanden compressor, new parallel flow condenser, evap switch, dryer, new barrier lines, and o-rings. But do I really need a new electric fan? I don't see why people are replacing that in the conversions. Are they more efficient? Greater CFM? I'm in AZ so looking for the best cooling possible :)
    '90 325is
  • tomstin
    • Mar 2015
    • 569
    I replaced my fan to basically complete the retrofit. I replaced / upgraded everything else and the fans are not that expensive. I also wired mine to come on high all the time with the AC (had to up-size the fuse). The newer fans are lighter and I believe higher CFM.
    2004 525i Manual - 1985 325E Coupe Manual
    • treff-7
      • Sep 2009
      • 345
      I had a '90 325i convertible when I converted mine. I kept everything original except for the dryer and all seals. It ran fine for several years until I swapped the engine. Had no leaks either. At idle it didn't work that well because the compressor wasn't designed for R134a but when the engine was above idle it blew nice and cold.
      • jeffnhiscars
        • Jun 2011
        • 6011
        SOP is to run the fan on high which does generate a fair amount of noise at idle. As has been said, a replacement fan is not very costly and will give you greater airflow with less volume. Not mandatory but not a bad idea WYAIT
        Alice the Time Capsule
        • digger
          • Nov 2005
          • 6170
          what are specs on the stock Aux elec fan vs a spal ?
