I'm replacing the power steering lines and banjo bolts on my Touring. The parts are interchangeable with a USA 325i. Below are the Touring diagrams from RealOEM. Part #3 is the 16mm banjo bolts and part #6 is the 14MM banjo bolts. I also want to replace the crush washers for all the banjo bolts. The 16mm crush washers (part #2) are grayed out on the diagram and have no part number. The corresponding USA 325i diagram incorrectly lists a 14mm crush washer for the 16mm banjo bolts.
I did find 16mm crush washers on a 325ix diagram with the following part number: 32411093597 . Can anyone confirm that this is the correct part number for 16mm crush washers? If not, can anyone please provide the correct part number?
Thanks, Cory
power steering lines diagram by cory58f5, on Flickr
power steering lines parts list by cory58f5, on Flickr
Thanks, Cory
