Help Installing Rear Quarter Window Seal (pop-out)
  • Capt. Science
    • Apr 2018
    • 5
    I’m trying to convert my ‘90 325i to pop-out windows, and have run into a roadblock when installing the window seals. This may be a product of inexperience, but a bit of the deal won’t fit when I try to work the seal onto the seam (see image).
    The seals are new and I’ve check that I have the correct part number (51361904827) on realoem and bmwfans.
    If someone could point out what I’m doing wrong or give me advice on how to force the seal onto the seam, Id love to buy you a beer. Thanks!
  • kyleconstantine
    • Apr 2014
    • 1380
    They are not set all the way in all the way around...they fit tight. Work your way around and force it in tighter.
    • brutus
      • Dec 2016
      • 596
      … I always tap mine in with a rubber mallet ,
      • Zambuzan
        • Nov 2017
        • 434
        Gee what a pain... I'm assuming you have to deal with the headliner as well? Also the broken clips from the picture? Crossing my fingers I never have to do anything rear-quarter related...
        "Time doesn't heal anything... It just teaches us how to live with the pain." - My Cracked Dashboard
        • tomstin
          • Mar 2015
          • 570
          Pull the lower right corner, where it comes around the bend, further back and make sure its setting all the way in. My thought is that bend isn't seated properly therefore you have that slack at the top. When I put the seal in for my windshield I had to wrestle the corners to avoid slack on the straight pieces.
          2004 525i Manual - 1985 325E Coupe Manual
          • packratbimmer
            • Dec 2009
            • 1335
            I usually glue the headliner in place with contact adhesive first so I do not need to deal with it staying in place. Start in the 90 degree corner and work your way around using methods described above. It will seat firmly.
