Under Body Fuel pump hoses
  • Nageek17
    • May 2015
    • 15
    Sorry if this was in a previous post already, I couldn't find the answer.
    I plan on replacing my fuel filter and out of the tank fuel pump and might as well replace the hoses while I'm there. I read somewhere I can just use a general hose rated for fuel and pressure. Does anyone have any recommendations on which one to buy and which ones fit? Or there some portions of the fuel lines I should order the OEM part?
    Maybe just getting the hose with the bend in it 16121178990 and the rest using a general hose?
  • ZEKTI
    • May 2016
    • 218
    For the standard sized fuel hose I like Gates Barricade fuel injection hoses. Cheaper than OE and a little bit better “feeling” than the CRP/conti brand. I know some guys like marine fuel hose as well. Sent from my iPhone using Tapatalk Pro
    OBD1 S52 E36 Compact
    84 318i M10 Zender
    • packratbimmer
      • Dec 2009
      • 1335
      I would take a look for any hoses with sharp bends. You might be okay with the external fuel pump setup, but I know that the later system has some U-shaped hoses that would certainly kink if aftermarket hose was used.
      • bradmer
        • May 2016
        • 373
        I believe it is this one that has the tight bend.
        Hose 1 06/1986 09/1987 16121178990
        From this page.
        http://a.realoem.com/bmw/enUS/showpa...diagId=16_0181
        I used oem fuel line in bulk from a local independent shop and ordered the pre bent hose above to go along with it.
        • Nageek17
          • May 2015
          • 15
          Thanks, just going to order that tight bend piece.
