M10 making weird noises, burning oil, and not idling properly
  • Dawskip
    • Feb 2018
    • 242
    I’ll attach a video of it.
    the car runs fine, other than why was mentioned in the title.
    if moving, the rattling goes away but as soon as I come to idle, it gets rough and I hear the rattle.
    any ideas??
    any ideas??
  • Sunnyledge
    • Nov 2017
    • 221
    A vacuum leak will cause a very erratic and rough idle that disappears at higher rpms. But this wouldn’t explain the oil consumption.
    • Dawskip
      • Feb 2018
      • 242
      Also doesn’t explain the rattling which is my main concern
      • Dawskip
        • Feb 2018
        • 242
        Bump pls halp
        • TobyB
          • 5272
          Measure your oil pressure with a gauge.
          Check your timing with a light.
          Bypass your idle valve with a manual one and see if it will then idle in a stable manner- the 318 idle system is known to be poo.
          A small ball valve from the pluming store can work for troubleshooting.
          See if your exhaust is loose/ hitting anything.
          See if you have a lot of blowby from the crankcase.
          Try a compression test.
          Unhook one plug wire at a time to see if the rattle goes away
          for starters...
          t
          other that that, Mrs. Lincoln...
          • EbzyyE30
            • Feb 2019
            • 62
            not sure if its the same system as m20's with the Motronic system. but I can say that these motors do not like vacuum leaks at all. just pull the dipstick while idling and you will understand very quickly, I would check every vacuum line for leaks, and for that rattling just sounds like the exhaust is bouncing around because of the bad idle just a lot of vibration. could be the shield that is loose as well. Good luck and check all the stuff the guy above has referred to.
