Sunroof Leak after new seal replacement & adjustment (not drain holes)
  • E30Bastard
    Shimmy Shimmy Ya
    • Nov 2018
    • 245
    Hi Guys,
    Mundane problem here but it's driving me nuts. I bought an OEM seal to replace the original one and I adjusted the sunroof per Bentley with two 4mm allens in the guide holes. Adjusted to 1 mill high in the back and 1 mill low in the front. Also blew out all four drain holes with compressed air and tested all 4 for drainage .
    I am still hearing air with the sunroof shut, I am also leaking water like crazy out of the rear portion of the sunroof where there are no drain rails. What am I doing wrong?
    "It wouldn't be there if it wasn't..." - Milton Berle
    1988 325iS - M20
  • twright
    • 707
    Electric or manual sunroof?
    • roguetoaster
      Biggus Tippus
      • 7830
      The stop position of the sunroof when closed needs to be something like the dwell above TDC on a piston so it's actually held shut. Basically, to rule that out just push up on the sunroof/interior cover (gently) and see if that helps. Otherwise the seal may just not quite have conformed, although mine was a very tight fit on the first close after a new seal.
      • E30Bastard
        Shimmy Shimmy Ya
        • Nov 2018
        • 245
        It's an electric sunroof. I can see light through the crack between the seal and the body. I've completely removed the vanity cover to troubleshoot this. Will give it another college try.
        1988 325iS - M20
        • jeffnhiscars
          • Jun 2011
          • 6010
          You shouldn't be seeing daylight. Keep in mind there are 2 OE versions of the seal..a 1 piece and a 2 piece. It's been a while but IIRC w the1 piece the joint should be at the rear center of the roof panel and w the 2 piece the joints should be centered on each side over the cross rail.
          Alice the Time Capsule
