Questions about the valve cover hardware
  • dice2012
    • Mar 2021
    • 52
    I was trying to torque down the hex nuts on my valve cover, but I couldn't seem to torque down the nuts under the intake manifold. So after reading many forum posts and coming up with more questions than answers, I just wanted to ask.
    Do I even torque down the nuts? It seems like a lot of people advise against using a torque wrench, instead opting to tighten by hand and not overtighten. What is the correct way to do this? If I should be using a torque wrench, what specs do I set it to? It seems like the guides say 11 ft lbs but others say that is too much. In trying to tighten the nuts back down with a wrench, I deformed the outside of a nut, so that needs to be replaced. Can I go to an AutoZone and buy any M6 X 1 hex nut? Is there a certain type I should buy? Lastly, what is the correct way to tighten down the nuts under the intake manifold? Really not trying to mess anything up.
  • Vincenze
    • Apr 2019
    • 990
    You need universal joint socket adapters to reach into tight places.
    If you don't tighten it correctly, oil will leak through the seal. You may even need to use a high-temperature sealer.
    • dice2012
      • Mar 2021
      • 52
      I'll have to get one of those. Thanks. Any info on the correct torquing specs and/or the hex nuts?
      • Vincenze
        • Apr 2019
        • 990
        The hex nuts appear to be generic.
        Yes, Bentley says 11 lb/ft.
        But you must use the same torque sequence as for the engine head: start from the center.
        • dice2012
          • Mar 2021
          • 52
          Thank you! I'll need to get a copy of the bentley soon along with those joint socket adaptors.
          • tomstin
            • Mar 2015
            • 562
            I think you will find a ratchet with a flex head or, what I uses, a short handle ratchet will work better than the flex joints. I use the short handle (stubby) ratchet the most as it limits the torque you can put on the smaller fasteners. As examples:
            Stubby: http://corporate.cornwelltools.com/w...Chrome%29.html
            Flex head: http://corporate.cornwelltools.com/w...d-Ratchet.html
            2004 525i Manual - 1985 325E Coupe Manual
