Gotta love bad brakes
  • fletcher miller
    • Sep 2004
    • 78
    So i ran my brake pads down to the back plate and destroyed my rear passenger rotor. Since i still live at home my mom said that i can just repalce all the pads rotors and hoses, so I'm hooking my self up with new stock hoses, Ate performance font rotors, ate stock repalcement rotors, pagid pads all the way around. Now the info i need is how do i bleed the calipers on a 91 318is, or would 325is rotors fit under my rims and cheaply upgrade to larger calipers? need lots of in for many details thanks
  • ZiMMie
    • Jun 2004
    • 968
    Buy a bently's manual or haynes manual it will help u out a lot.
    www.stancefactory.com
    • James Crivellone
      Head Janitor
      • 6305
      you may wanna check other parts of the car if you were dumb enough to let the brakes get that worn out.
      mean, but I have a point
      • jblack
        • Aug 2004
        • 98
        Why would you not replace the stock lines with stainless steel? Firm up the pedal....it's all good. Do the Goodridge Teflon coated lines (available lots of places - www.bimmerworld.com ). The brakes should be the same among all E30's. I would not go with any special rotors- the stock replacements are on my 325i Spec E30 race car - trust me, if it will live up to that, it will live up to very aggressive street driving....
        I would go with Goodridge lines, Axxis Ultimate pads all around, stock rotors. If you want to go with some bling - get the calipers bead blasted (like 30 bucks at a body shop) and paint them black or silver. You will have better brakes than 90 percent of the E30's around. If you want extra bling, get the ATE slotted rotors - they will wear your pads out quiker, with little benefit, but there is benefit of "freshening" the pad. Also, get some ATE Superblue fluid - it is cheap and easy too. You are talking small money here for big improvement.
        • robert325is
          • Aug 2004
          • 1171
          just for future ref... you might wanna check your brake pads every once in a while.... it usually helps
          • Super Eta
            • 1884
            I should replace the brakes and rotors on my beater since they are now atleast 3-4 years old. Hey they still have some life left on them. 8)
            • James Crivellone
              Head Janitor
              • 6305
              awesome, I am thankful you provided such awesome information for this thread
              • fletcher miller
                • Sep 2004
                • 78
                Well i convinced my dad to replace all the rotors, pads and lines on the car. Ate in the front with stainless hosses all the way around, and stock pads
                • e30Matt
                  • 5077
                  What happened to the wear sensors? Did they disappear?
                  • DSchultz325e
                    • Aug 2004
                    • 1158
                    probably weren't replaced last time brakes were worked on (woops)
                    I retired my E30 for now...
                    E46 323i
                    David Schultz
                    • fletcher miller
                      • Sep 2004
                      • 78
                      I've only had the car for a month and a half so i don't really know whats been done with the brakes or any other part of the car
                      • Digitalwave
                        is a poseur
                        • 6299
                        Re: Gotta love bad brakes
                        The calipers are the same on a 318iS and a 325iS.
                        The thread title should be "Gotta love idiot car owners" not "Gotta love bad brakes."
                        RISING EDGE
                        • T.Dot E30
                          • Mar 2004
                          • 536
                          Ya there is nothin wrong with the brakes, all you gotta do is change them when needed.
                          thats like Running ur tires till they are bald, are u gonna call them crappy tires bcus they suck when they are bald.
