BMW M3 Engine Identification
  • BRONXBK
    • Dec 2009
    • 5
    Does anyone know how to ID a e36 M3 engine? I do know of the markings on the center/drivers side between the oil pan and the tranny but was not able to check since the engine is not in my possession as of yet. The seller did give me some misc. numbers which are:
    11.671744250
    and
    0375
    If anyone can shed some light on this it would be most appreciated!!!
  • ethirtydavid
    • Jan 2008
    • 2331
    There will be a VIN number on a thin metal plate on transmission side of engine in the back on the head. Sometimes this can go missing though. One other sure place to find true identification is found on the block right by the driver side engine mount arm (firewall side).
    -Read that number to BMW dealership and they will be able to identify the engine
    GL
    • ethirtydavid
      • Jan 2008
      • 2331
      this will help too -
      Originally posted by DesertBMW
      Under the serial number there is a engine code:
      30 6 S1 (is 1995 3.0L M3 engine)
      25 6 S1 (is 2.5L M50 engine)
      32 6 S1 (is S52 engine)
      28 6 S1 (is 2.8L M52 engine)
      25 6 S2 (is 2.8L M52 aluminum block engine)
      30 6 S3 (is 3.0L M54 aluminum block engine)
      • bmwdready347
        • Jan 2011
        • 586
        :o
        11.671744250
        and
        0375
        • reelizmpro
          • 9558
          I'm sure the guys in the swap forum would know.
          88 M3 - LACHSSILBER
          89 M3 - ALPINEWEISS II
