e30 m3 high mounted brake light?
  • george graves
    • 20003
    How does the high brake light mount up on the e30m3? Anyone have a pic? Can it be transferred to a non-m?
    Originally posted by Matt-B
  • reelizmpro
    • 9558
    Good question. I shall have a look at my spare. There must be 2 holes in the body because the light has a plastic bracket with expanding rivets with screws in the middle that expand when you fasten them down. I don't think you can properly install one in a regular e30 due to the difference in angle of the rear window.
    88 M3 - LACHSSILBER
    89 M3 - ALPINEWEISS II
    • george graves
      • 20003
      ^ah. Good point. Maybe the "bezel" of the light could be trimmed. I would like to the the body mounting point if anyone has a pic.
      • reelizmpro
        • 9558
        Yeah true, I'm sure it's possible but not without modification. Also, these things are expensive and very hard to find. May not be worth it unless you score a deal.
        88 M3 - LACHSSILBER
        • george graves
          • 20003
          Why so rare? What years did they come on?
          • reelizmpro
            • 9558
            Because they only came on M3's so it's a specialized part. Expensive new and hard to find used.
            Realoem says $130.
            88 M3 - LACHSSILBER
            • Farbin Kaiber
              Lil' Puppet
              • 29502
              Doesn't it mount to a totally non existant part of a non M e30?
              • george graves
                • 20003
                Well, that's not that rare.
                • boomer
                  • 3019
                  The e30 M3 has a metal base welded to the ceiling,where the third brake light
                  is mounted to.The third brake light will fit flush on a regular e30,but there's no
                  provision for mounting it to the ceiling.
                  I found this out when I tried mounting a third brake light to my coupe.You would
                  have to remove the headliner and improvise some kind of mounting base in order
                  to attach the brake light to your non M e30.
                  If you're interested,I can sell you my third brake light unit,as I've decided to go without
                  a third brake light.
                  http://www.arghon.com/
