Building an S14 part by part?
  • blunttech
    • 12850
    Ive sold 2 complete s14's piece by piece to 2 different guys and you have no idea how much it costs.. Neither did the guys who bought them by the time they were done
    sales@blunttech.com
    www.blunttech.com
    Like us on Facebook
    • M-technik-3
      • 18946
      Exactly, Jake's wallet must be very light right now.
      • euro3
        • Aug 2004
        • 761
        I'm slowly purchasing a spare S14. (AKA MONEYPIT)
        I started by purchasing a new 2.5 block and crank....
        I found a complete cam carrier, upper and lower oil pan, and a set of 48mm throttle bodies on S14.net.
        $5-6K already spent, about $7-10K in parts still needed....
        • BillBrasky
          • Dec 2008
          • 1641
          Did you happen to check how many they had when you ordered it? I bought one last December and there were 5 remaining after I ordered it. I'm just curious if they still make production runs on them or not.
          • Massimo
            • Jan 2008
            • 3207
            What is the differance between the 2.5 and 2.3lt block are the bore walls diameters bigger to allow for a bigger bore?
            Yeh if it is going to run me up to 10k just for the engine I supose not?
            Steve are you talking about brand new parts I am looking at second hand.
            Also not looking at getting ITBs as this would be a learning project as well I would probebly look at making something like this intead,
            I know I am crazy. lol just a thought at the moment. depends if I can get my hands on soildworks and buy a 3d printer.
            Cheapish 3D printer
            What I would be looking at getting is
            Block
            Head
            Cam carrier
            Cam Cover
            Crank
            Timing chain and guides.
            Everthing else will be custom or after market. That means
            Valves, springs, retainers, caps, guides, cams, buckets and shims, pistons, conrods, dry sump (maybe), exhaust and intake system, and fuel delivery. Will be aftermarket
            • ethirtydavid
              • Jan 2008
              • 2331
              You can buy a lot of engine for that kind of money, built and installed. You set on getting an s14?
              • Massimo
                • Jan 2008
                • 3207
                Well like I said Ill probably turbo the M42 before I go the S14. But yeh I deffenetly want an S14, the sound they make is addictive and I want it.
                On another note thinking about a Euro 2lt version. I have been contimplating competing in the 2lt sports sedan series here, this would be a great motor to use.
                • Jables
                  • Jan 2010
                  • 83
                  litre for litre M42 > S14
                  • YAN-3
                    • Jan 2004
                    • 6018
                    Originally posted by M-technik-3
                    Buy a complete engine or plan to bleed heavily.
                    the truth right there
                    dude, a 300hp S14? you understand your talking about easy $12K+ motor build
                    and trying to source parts seperatley will always cost you more than buying it all together.
                    If you want 300hp why not go with an S50/52? way, way, WAY cheaper than trying to squeeze 300 out of a S14
                    with over $6K+ into my S14, Im still under 200rwhp so say its around ~240hp at crank :(
                    • frankie591
                      • Feb 2012
                      • 545
                      for that money just buy a metric mechanics motor...
                      • blunttech
                        • 12850
                        The 2.5 blocks have lots of extra webbing for rigidity and provisions for squirters.
                        Cheapish 3D printer
                        Block
                        Head
                        Cam carrier
                        Cam Cover
                        Crank
                        sales@blunttech.com
                        www.blunttech.com
                        Like us on Facebook
