find the leak please
  • Cabriolet
    • 9620
    did just my tensioner die or is it the Headgasket?
    20130527_111338 by Eric Berger, on Flickr
    20130527_111344 by Eric Berger, on Flickr
    20130527_112715 by Eric Berger, on Flickr
    Much wow
    I hate 4 doors
  • Todd Black 88
    • Oct 2007
    • 3449
    Degrease the area, wash it all off, and go for a drive.
    Originally posted by codyep3
    I hope to Christ you have looks going for you, because you sure as fuck don't have any intelligence.
    2001 silver/Blk 325 cabby. SOLD
    2002 325xit Sil/blk. SOLD
    2010 F650gs twin
    • Cabriolet
      • 9620
      the engine isnt running all that smooth so im a bit worried to drive it. kinda like ticking sound
      Much wow
      I hate 4 doors
      • the imitator
        • May 2013
        • 1006
        Tick is better than a knock, imo clean off the pre exisiting oil as described above and just sit there and let her idle and see if you can track where the blood is coming from.
        • Boostesi
          • May 2011
          • 220
          id hit it with some brake parts cleaner, and blow it dry with the compressed air if you have a compressor/ blow gun. if not, loosen the heavy with a wire brush and hit it with some good quality brake parts cleaner and it will look all new and shiny, then let the car idle, you dont have to take it for a drive. your car maintains oil pressure at idle and if you let it run long enough will start to leak again.
          sigpicFellow e30 enthusiast
          Dont waste your time hating, aint nobody got time fo dat
          1986 bronzit 325es- SOLD
          1987 delphin 325i- parts car
          1990 scwarz 325is- m50 drift slut
          CHECK OUT THE BUILD!
          http://www.r3vlimited.com/board/showthread.php?t=229234
          • 7pilot
            • 475
            Clean the area up.
            Adjust the valve clearances. This may be a reason for your ticking.
            Upgrade to the E36 tensioner wth a new ring.
            Don't over tighten.
            If it still leaks, change the cam cover gaskets.
            Replace that water hose, it has been cut almost clear thru....The clamp has been waay overtightened.
            If the ticking is absent at cold start but comes in as the oil warms up, you'll need to check the rod bearings.
            m
            • Cabriolet
              • 9620
              it was the tensioner but got to it 1 mile too late. lost all 4 qts in 1/2 miles. now cyl4 has valve tick that i will have looked at next week.
              Much wow
              I hate 4 doors
              • reelizmpro
                • 9530
                Just saw this...damn that is a mess. S14's aren't the cleanest engines as they do tend to leak but that's excessive. Hopefully, it's just the tensioner washer and not the timing cover as well. Hopefully the low oil pressure didn't damage anything in that 1 mile. Many years ago, when I first bought my M3 it was leaking from both pan gaskets, timing cover, valve cover as well as the oil pressure switch. Oil was seaping through the switch itself. I was running low on oil and the engine started smoking at idle. So I took it easy on the way home which was a few miles and after all that, the engine turned out to be alright.
                88 M3 - LACHSSILBER
                89 M3 - ALPINEWEISS II
                • Cabriolet
                  • 9620
                  Barry the car is at a shop getting the valves adjusted. cylinder 4 has a bad tick and i'm hoping it will be fixed. otherwise im looking at a full top end rebuild.
                  Much wow
                  I hate 4 doors
