Any reason not to put 225/50/15s on a stock M3?
  • markseven
    • Sep 2006
    • 5327
    I am thinking of putting 225s on my stock 15" weaves. Is there any reason why I should stay with stock size tires?
    The E38 Style 5s with new Direzzas may be up for sale soon...
    I Timothy 2:1-2
  • 02fanatic
    • Jun 2008
    • 41
    I think you will be fine with 225/50/15's...205/50/15 is the stock size as I recall, so this is a common upgrade...just a little wider tread width. When I bought my car the spare in the trunk on a stock wheel was the 225.
    I can't say for sure you won't have any rubbing, but I doubt it will be an issue as the offset of the stock wheels is ET30...they are pushed inward enough to allow for alot of fender clearance.
    John
    • markseven
      • Sep 2006
      • 5327
      Thanks John!
      I Timothy 2:1-2
      • BlackbirdM3
        • 2769
        I run 225/45/15s on my stock wheels. No issues here.
        Will
        '88 BMW M3
        • markseven
          • Sep 2006
          • 5327
          Will
          Thanks Will!
          It appears that only R comps are available in 225/45 - I'm looking for a summer tire, somthing predictable...
          I Timothy 2:1-2
            • 37829
            Stock is 205/55/15.
            The 225/50/15 would keep the same overall height as stock but run wider of course.
            They'll definitely look beefy on the stock M3 wheels!
            Classic BMW Specialists
            Grover Beach, CA
            www.BimmerHeads.com
            • markseven
              • Sep 2006
              • 5327
              Will
              Originally posted by MR 325
              Stock is 205/55/15.
              Matt, yeah, same diameter as stok, but will fill the wells a little better :)
              I Timothy 2:1-2
              • Cabriolet
                • 9620
                225/50/15 RA1s not issue and im lowered
                IMG_5075 by Eric Berger, on Flickr
                Much wow
                I hate 4 doors
                • markseven
                  • Sep 2006
                  • 5327
                  ^ lookin good, amigo.
                  I Timothy 2:1-2
                  • M-technik-3
                    • 18946
                    I run RA1's on my Revolution in 15x8 and some Kumho in 225-50 on stock baskets and they work fine even on a lowered M3. No issues enjoy the lighter weight wheels, not much point to go with bigger diameter other than aesthetics.
                    • nrubenstein
                      • 3148
                      RA-1s are GREAT street tires, for what it's worth. Their temp range is, honestly, probably wider than the Z1, they are surprisingly quiet, and they are great in the wet. Tread wear is also good.
                      2002 BMW M3 Alpinweiß/Black
                      1999 323i GTS2 Alpinweiß
                      1995 M3 Dakargelb/Black
                      - S50B32/S6S420G/3.91
                      1990 325is Brilliantrot/Tan
                      1989 M3 Alpinweiß/Black
                      • BlackbirdM3
                        • 2769
                        Thanks Will!
                        I'm running Hankook RS3s, not R compounds. http://www.tirerack.com/tires/TireSe...earDiameter=15
                        Will
                        '88 BMW M3
                        • 02fanatic
                          • Jun 2008
                          • 41
                          Thanks for correcting me on the stock tire size...obviously, I don't run stock...:-) But, I do recall the 225/50 being about the same height as the stock 205/55.
                          John
                          • ex566
                            • Sep 2013
                            • 13
                            i run them, they work perfectly fine although i prefer less sidewall ...
