The 5 Year Restoration - E30 M3 Reborn
  • jhaurimn
    • Nov 2012
    • 2224
    #256
    Cant wait to see this thing painted and watch you meticulously put it back together, just as you took it apart. :)
    Current:
    1989 325i
    1988 M3
    1987 325ic
    Past:
    2001 330ci
    2001 M3
    • CurrusDei
      • Mar 2014
      • 673
      #257
      Thanks guys. Catching up some
      I first removed the cover from the bell housing that pulls away to reveal the flywheel and the sensors that are housed near it – one is called the flywheel crankshaft position sensor (12141708619) and one is called the position transmitter (12521287784)
      Cover
      Bolts – I belive the big ones go in front, small ones in rear, but don’t remember
      Bolts out
      I pried the cover off gently with a plastic pry tool so I didn’t scratch any metal
      I also disconnected the support that holds the exhaust manifold downpipes to the transmission housing. Bushings obviously need to be replaced
      note how the lower part attaches
      Coming off
      Clutch slave cylinder removed
      Sensors here
      Here is the top end of the Crank position sensors
      Top sensor (don’t know which is which yet, Ill figure it out later)
      Bottom sensors
      Bolts that hold on the heatshield also hold on the sensors
      Then they pull out
      Oh time for these gems of transmission mounts
      This one was… not doing its job
      Other one was at least whole
      Up next, separating engine and trans.
      _______________________________________________
      5 Year M3 Build, In Progress
      RMT200 Retrofit
      • CurrusDei
        • Mar 2014
        • 673
        #258
        To separate the transmission from the engine, these seven bolts must be removed
        Passenger side
        Top bolt here holds in the starter
        Three bolts on the top here – Big one just left of center is the other starter bolt. Top two come off as well
        You can see the bolt positions here (looking ahead a bit – 4 are used for the engine stand, the other 3 are empty)
        When you remove the two starter bolts the starter will stay in place if you haven’t removed the screws in back.
        Mine had a snail under it. He was thoroughly roasted – nothing left but the shell. Cue the slow car jokes, right? We’ll count it as good luck.
        I jerked the transmission back a bit by hand, then it didn’t want to move
        Bring back out the cheapo Harbor Freight pry tool and the mallet
        Worked by way around the housing, prying gently. Tore up the plastic pry tool a bit, but who cares – its like $5 for a set.
        And off she comes
        I was surprised at how light the transmission is. I can pick it up by myself pretty easily. Its not light, but I expected a lot more weight.
        Clutch pack coming off
        See how all the bolts came out easily….
        …except one. Dremmel scars from cutting off the bolt that stripped. Going to replace the pressure plate and clutch, so no worries.
        With the pressure plate off, the clutch comes off easily and there are 8 bolts holding on the flywheel
        Impacted those off, and a few whacks with a soft mallet..
        I wasn’t sure if the starter would interfere with the engine stand mounting point, so I took it off before mounting the engine. The two main bolts were removed when I took off the transmission. The teeth of the starter normally hook into the fly wheel but that has already been removed, so the only thing I had left was where the back of the starter attaches near the arm that supports the air plenum from underneath.
        You can remove the two bolts on the bracket, but I just removed the bolt that holds both the bracket and the air plenum support arm.
        Then it will pull straight out
        Now for this engine stand. I wanted to mount the engine so that the valve cover was facing straight up to make it easier to work on. The issue is, the engine sits in the car tilted over to the right a bit. I spent an hour or so trying to match the engine to the stand using various positions of the hoist – it was a pain. Things went MUCH smoother when I took the stand apart and assembled it on the engine in the air.
        I put down the stand but the engine wouldn’t rotate, took it back off and greased it with some thick all purpose grease.
        The first time I put the engine down I matched the insert to the stand. This time I just lifted up the stand and put it on the insert.
        It shifted a bit, but was still upright.
        WARNING: If you follow this strategy, be VERY Careful when putting the engine down and keep the hoist attached and the chains tight until the stand is on all four wheels. Do not try to lower it too fast. I put mine down carefully and it still tried to fall over to the right. I leveled out the stand with my body weight and it never got away from me, but if someone was hurrying this could go badly. It’s a lot of weight and can be dangerous. So, be careful.
        I used hardware from Fastenal to mount the engine. Some guys have used the OEM hardware, but I don’t think the top bolts work. As best I can remember, these are the sizes I used. (got from S14 .net thread here: [IMG]http://s14net.vbulletin.net/forum/s14/general-e30-m3-discussion/46136-putting-an-s14-on-an-engine-stand)
        (2) M8x1.25 70mm length
        (2) M10x1.5 70mm length
        A few pics
        RMT200 Retrofit
        • ChaosTheory
          • 517
          #259
          makes me wish i didn't sell mine. Life forced me too. One day I will get another E30 M3
          • JosE30rejel
            • Sep 2015
            • 1
            #260
            Quite the work you have done so far but inspiring none the less. Never had an E30 M3 but due to your work Ill be looking forward to getting one in the future, cheers!
            • Chris4soc1
              • Dec 2009
              • 105
              #261
              Great thread! Keep up the good work!
              • CurrusDei
                • Mar 2014
                • 673
                #262
                Thanks for the kind words guys. As of now, there is nothing left for me to take off the outside of the car and the next step is the chassis dolly. Time to catch up on the thread
                Removed a bunch of stuff off the trunk, don’t remember if I posted this yet
                This will need to be replaced, don’t want water in the trunk
                Next up was the wiring harness. I went back and forth on if I could leave part of it in the car so that the engine bay could be painted, or if I should just take the whole thing out. Ultimately I elected the latter option – why go this far and pull up short on this item. I do wish that BMW had put in a quick disconnect through the firewall or below the fuse box. This is one BIG harness.
                MESS
                I decided to start at the back and work my way forward. So – to the trunk.
                Here’s the amp bypass from my stereo thread
                Lotsa more wires, the two bare wires go to the trunk open/close sensor – not sure why they were cut, but they’ll be being repaired when I overhaul the wiring harness.
                The black wire without tape on it goes up into the roof of the trunk and to the light. Sorry for the blurry pics.
                One wire runs around the driver side of the trunk and makes a 90 degree turn to run under the rear trunk lip over the tail lights.
                This contains the connections for the tail lights, trunk lock, license plate lights, and rear reflectors.
                Running under the trunk lip
                Driver side wire dropdown. The black connector is for the tail lights. The white connector is for the rear reflectors.
                Here is the driver side rear reflector
                Same on the passenger side. You can see one of the license plate lights here.
                Driver side license plate light
                Cable tie on driver side that holds cables going to the rear light check relay.
                Close-up of the metal tab that holds the wiring harness in
                Wiring hanging
                The trunk illumination light pops out easily
                License plate lights have screws
                Looks like there has been some corrosion – probably will try to replace the connections
                Disconnected the rear trunk actuator
                Here it is
                and the lock mechanism that it moves
                See where it connects to the push button trunk release in the white clip by my finger (with overspray on it – grumble)
                And off comes the spoiler
                Bolts off
                When the bolts are off the spoiler just lifts out. Feels very heavy compared to the CF spoiler.
                Negative wire terminal off
                Positive terminal runs through the conduit shown here and through the rear seat wall
                Conduit/cover off
                Comes out under the red bar shown here, under the brown padding
                Now, to get the harness fully out, you have to disconnect the speed sensor at the differential, electrical connections to the fuel tank, and other things underneath the car. Coming in next update.
                RMT200 Retrofit
                • wark
                  • Jul 2013
                  • 321
                  #263
                  Nice work! Sub'd for more.
                  Dustin Wark | Instagram ・tumblr・Flickr
                  • CurrusDei
                    • Mar 2014
                    • 673
                    #264
                    Alright, Thanksgiving. Time to bring this thread current :up:
                    Before I could free the back part of the wiring harness I had to get under the car to free a few sensors that tie into the main harness
                    Looking up from the bottom into the back seat
                    Speedo sensor comes off the diff
                    Brake wear sensor
                    I took a handful of videos tracking the path of various lines under the car.
                    This seemed more efficient than test and photos.
                    Some wires run to the fuel lever sensors and pumps
                    The two you see in the picture above run off the back of the fuel tank. Not easy to get out but unbolting the tank gives you some more clearance.
                    Some lines run over to the fuel sender pump
                    Pulling wires from the underside to the topside
                    On the topside
                    Part of the wiring harness runs over to the passenger side
                    On the passenger side, some of the wires split off from the main harness by the rear seat brace bar
                    These wires continue down toward the door sill (the white translucent clip (not the one in my hands) around the wires here plugs into the sheet metal on the inside of the door sill.
                    This connector looks a bit singed. The connection goes to the overhead lights.
                    Moving toward the front, here is the door sensor and speaker
                    You’ll notice on the passenger side that there are two main “sets” of wires that run down the side, one crosses over from the main harness that runs down the driver side, the other runs from the positive terminal on the battery down the passenger side and up into the engine bay. Here you’ll see where I have started to coil up this positive terminal wire.
                    Positive terminal wire goes up a series of tie downs and into the engine bay
                    Nice and wrapped
                    Cleaned, taped, and tied
                    There was one wire left when I had cleared out the others
                    It runs back to the gas tank flap lock, easy to disconnect. The actuator comes off as well
                    On the driver’s side, separating the wire that runs up to the ceiling reading light
                    Complex junction around where the left side of the driver seat would be
                    Floor spaghetti
                    Passenger door wiring connection coming out
                    Passenger speaker
                    Harness running under the passenger seat area
                    Passenger side rolled up
                    Unattaching sensor on hand brake
                    Going over the transmission tunnel
                    and back down the other side
                    This guy was just coiled up under my seat. Quick research says its the seatbelt buzzer sensor.
                    Front driver side speaker
                    steering column
                    four screws hold on the stalks
                    I read that this is the seatbelt buzzer relay
                    Plastic cover over a set of relays behind/below the front driver speaker.
                    Ugh, such a mess
                    There was one more electrical attachment in the engine bay – I think this is the Fuel Tank Breather Valve, but all the new ones are plastic
                    Now, find someone to help with this part. The entire harness has to be fed through a small hole under the fuse box. My buddy from my neighborhood (who works on VWs a lot) helped with this part. It is not an easy pass through – just go slowly, don’t break anything, and take a break if you get frustrated. After a while, your reward is a huge mess of wire on the floor, and some very skinned knuckles.
                    …and a very empty car
                    Handy use for my engine hoist box...
                    RMT200 Retrofit
                    • CurrusDei
                      • Mar 2014
                      • 673
                      #265
                      Actually there was one line left after the harness came out
                      It goes back to the fuel filler flap lock
                      And the drains from the sunroof empty through the side of the car through these vents.
                      The actuator comes out easily - screws here
                      NOW, for removing the rest of the engine accessories.
                      Starting inside, hood release cable
                      And the mechanism that releases the hood. Careful with this guy. I vaguely remember almost injuring myself taking this off, but dont remember how, so...good luck with that.
                      The grommet that goes through the firewall
                      Accelerator Cable Removal
                      Firewall insulation was peeling badly everywhere. Looking forward to replacing
                      Heat sheild coming off
                      could stand to be replaced
                      As could its hardware - unless the titanic museum wants them back
                      *Edit: ordered a new heat shield and hardware as part of my to me-from me christmas gift :-)*
                      potato photo of the insulation retaining bits and the downspouts from the ac box
                      Another potato photo, passenger side insulation
                      Clips that hold the O2 sensor wire
                      ...and with insulation removed
                      Grommets that the wires for the front brake sensors pass through
                      And removing shift linkage. This boy was pretty tired. Explains why the shifter would swing back and forth like an inverted grandfather clock pendulum.
                      Potato again
                      RMT200 Retrofit
                      • CurrusDei
                        • Mar 2014
                        • 673
                        #266
                        Tried to pressure bleed the brakes to flush out all the old fluid - but the brakes were sitting on my shelf, so i couldnt depress the pedal.
                        The Pressure wasnt getting past the ABS unit, so, time to take off the ABS unit, after we take off the evap stuff
                        More on where that Fuel Tank Breather Valve goes
                        And fuel feed and return lines
                        Now, ABS unit. I did way more labeling here than is necessary, but painters tape never killed anyone...that I know of.
                        The lines run through the round rubber grommets you see on the right of this pic, and the cylinder in the middle is the brake pressure regulator.
                        More tagging
                        Disconnecting from the chassis
                        fast forward, and...
                        The anti-vibration feet are two piece metal and rubber
                        Then I manually drained the fluid and caught the excess in a rag. Air compressor helped here
                        And unattached the brake lines from the junction point with the rubber brake lines in the wheel wells
                        Solid lines out. These were in really good shape. With some cleaning up/polishing i think Ill reuse these.
                        Brake line free engine bay
                        How she sat then.
                        RMT200 Retrofit
                        • CurrusDei
                          • Mar 2014
                          • 673
                          #267
                          Sideskirts coming off
                          Four clips with these screws hold the bottom of the side-skirt to the frame
                          The front and rear of the side skirts are held on by pins and a bolt
                          And several clips along the top. I just gently popped them lose
                          Removed the rear undercover plates – easy to figure out
                          Here are some pics - there were sedementary layers of dirt in here - probably from the first Bush administration.
                          This guy was chipped. Will replace
                          Rear exhaust hanger
                          The rear bumper removes just like the front – two square plastic covers hide the two bolts that hold the bumper on. I removed these and it slid off easily
                          Found my rear reflector
                          Removed the wiring and the plastic battery tray
                          The brown is dirt and gunk, not rust
                          Rear bumper and skirts off
                          RMT200 Retrofit
                          • nauqneyugn
                            • Oct 2012
                            • 201
                            #268
                            Are most of the pictures on this page not showing up for anyone else?
                            • CurrusDei
                              • Mar 2014
                              • 673
                              #269
                              I just logged in from another browser not logged into my account. Looks like the hosting linking changed recently. Is this the last photo you can see?
                              .if so, i have a looooot of pics to rehost
                              RMT200 Retrofit
                              • nauqneyugn
                                • Oct 2012
                                • 201
                                #270
                                Yeah, that's the last one I see. I like pictures; looking forward to you rehosting them. :)
