that carbon wing is HOT HOT HOT
					The 5 Year Restoration - E30 M3 Reborn
 Thanks for the kind words guys. I'm on vacation this week, so time to bring this thread current...
 Wiring Install.
 You saw the wiring removal and labeling. I was somewhat surprised that the reinstall was MUCH easier than the removal. This was because I took a lot of pictures, was very careful with labeling, and significantly improved the tape wrap coverage vs before when the tape was disintegrated and dry rotted.
 Replacement fuse box labels. These took a LONG time. Took millimeter measurements, and had to figure out what was written on my old ones. They weren't in awesome shape...
 I couldnt figure out the logo in the upper right. I even called owners of very low mileage cars, and did research for who printed BMW's fuse box circuit boards in the 80s. No luck, until I was rooting around in the garage for something else, and came across this guy in a pile of junk that came off the car - none of which has been thrown away, for instances like this.
 BINGO.
 Kroschu. Logo found.
 Final production:
 On
 Heading back in. Had to borrow a blanket to keep from scratching up the side - much more the white glove treatment going back together
 Driver footwell relays
 Taking time to get the harness secured and neat. Wont be complete until I put the dash back in, but this is still a huge improvement over the scattered mess i had when i started.
 Doors wiring cleaned up nicely
 Speaker Wire
 Replacement door tumbler - much better
 time for door lock actuators - had to cut new adhesive circles to cover the openings. Had some good 3m clearbra material on hand.
 Wired. The rest of the wiring runs low (see the zip ties - thats the factory method), and the wires that run up go through a couple of clips.
 Back to the floor, passenger side.
 and from the driver's side
 glamour shots
 Front
 Back
 Carpet going in
 Shaping foam back in
 Out
 Of
 The
 Park
 Damn.
 That harness install looks factory new.
 Ok you need a vacationI BUY/SELL REFURBISHED CM5907s & CM5908s
 HOWTOs:
 DB vert plastic bumpers
 OEM Keys
 MTech1 docs
 88 ix Lach/Card
 91 ic Calypso 3.1
 86 Cosmo 2.7
 OEM+ or bust!
 e30m3s54turbo: I save my money for tuner parts.Comment
 The wiring install is still missing the new fuse box cover i have, but its not going on until finishing touches. Dont want to risk scratching/breaking it while installing other motor stuff.
 Gas tank bump stop (this was missing when i got the car)
 Underbody trim (bday present from sis - yeh im hard to shop for)
 some slight sagging in the rear bumper plastic - probably standard for age and fittament in the 80s. my new bumpers do this sometimes.
 Some of the floor drain plugs were a little beat. One in particular wouldnt stay in, so I upgraded them all to the new style which has a heat melt seal around the edge. Heat gun on them for 5 seconds, press down, and done.
 Trunk time
 no metal on metal please - cut a foam gasket to go around the edge
 Wires wires wires wires
 Upholstery (also, diaper boxes make good hardware storage)
 Put this guy on the top of the spare tire wheel post so the carpet could go back in. It sits a little high, might be able to adjust or I might go to the post cap that isnt also a center cap wrench.
 Rear bulkhead cover. Mine was a little worn, so i had it covered in the same vinyl that the forward headliner is made of. Looks a lot better than the cheap paper material it had before
 Scoring for plugs. The red spots were on the front as well - not sure how that happened.
 People who call oil "black gold" havent seen the pricing on these boys. OEM door weather strip...
 Speeaking of birthday presents....
 I bought these thinking they were likely going NLA. Then i learned BMW has over 600 in stock in Germany. Guess they know what they have and are trying to keep them to M3 models because pricing is
 Didnt put these on yet, just laid down for pics. Will go on with finishing touches (roundel, badges, etc)
 Oh my. I have just witnessed excellence in its highest form.
 You sir are an inspiration.
 Amazed.My previous build (currently E30-less)
 http://www.r3vlimited.com/board/showthread.php?t=170390
 A 2016 Toyota Tacoma TRD 4x4 Offroad in Inferno is my newest obsessionComment
 Watching this always gets a smile on my face. This is something so enjoyable. Those little details, exact pictures, everything.M3 Sport Evolution 1990
 M3 215hp 1990
 318i 1988
 My restoration project: https://www.r3vlimited.com/board/sho...d.php?t=399373Comment
 Current:
 1989 325i
 1988 M3
 1987 325ic
 Past:
 2001 330ci
 2001 M3Comment
 3 Years in... Rebuilding an E30 M3.
 So i did a thing...
  Last edited by CurrusDei; 07-13-2017, 06:19 PM. Last edited by CurrusDei; 07-13-2017, 06:19 PM.Comment
 ohhhhhhhhhhhhh. that's on a whole other level.. $120k EAG car in process.I BUY/SELL REFURBISHED CM5907s & CM5908s
 HOWTOs:
 OEM Keys
 MTech1 docs
 88 ix Lach/Card
 91 ic Calypso 3.1
 86 Cosmo 2.7
 OEM+ or bust!
