5 lug rear ??
  • Jason89i
    • Sep 2004
    • 875
    5 lug rear ??
    going with the e36m3 fronts. Would like to keep the wheel offset (and wheelbase) the same front and rear (et40.) What do you recommend for the rear? z3 2.8 hubs? z3 1.9 hubs? or ??? will my e30 m3 axles fit right into them? thanks, jason
  • Aptyp
    • 6584
    • Jason89i
      • Sep 2004
      • 875
      Originally posted by Aptyp
      read it many times. really appreciate all the work put into this. I did my own 5-lug 6 years ago with 318ti parts. I thought i had it all figured out...... but you guys have taken it to a whole new level.
      Goals:
      larger (stock 86+ 325) rear bearings
      offset to match the front (et40)
      track width to be the same front and rear.
      after reading the html about a million times, i just get more confused. I would assume I should use the (I6)z3 hubs, stock bearings, 325i trailing arms. will my track width be the same (within a few mm) as the front?
      What halfshafts???? the e30 and e36's have different abs rings. So, should I just replace the rings? new halfshafts?
      thanks, jason
      • Jason89i
        • Sep 2004
        • 875
        Originally posted by Jason89i
        .... I would assume I should use the (I6)z3 hubs, stock bearings, 325i trailing arms. will my track width be the same (within a few mm) as the front?
        anyone?
        • 1990m3
          • 1180
          which car is this for?
          • george graves
            • 19996
            So whats the answer?
            Originally posted by Matt-B
