Are Treehouse CAB's more offset than OEM E30 M3?
    • 37834
    Wondering if the Treehouse bushings improve the caster (wheel centering) issue more than the OEM E30 M3 bushings.
    Grover Beach, California
    BimmerHeads.com
  • samiam3356
    • Jul 2009
    • 1901
    Treehouse claim's they do, so thats what I put on my car for my 5 lug swap (e36m). Also gave more clearance for the exhaust on the 24v swap. My wheels sit perfectly in the middle with them, so no complaints here just yet.
    Originally posted by Roysneon
    $5 shipped?
    Originally posted by MarkD
    You are a strange dude, I'n not answering any more posts from you.
    • kalib0y
      • Dec 2004
      • 3620
      yep, I dont know by how much but they did push my wheels up a little bit. Before that I had oe m3 bushings
      95 7.1L 16V E36 M3
      Motorsport Hardware ***Wheel studs and Spacers!!!--->FOR SALE 4/5 Lug Stud Conversion Kits available CLICK HERE
      LIKE my Facebook Page! CLICK HERE
      • E30FTW
        • Jan 2008
        • 76
        Yes. Not a lot, but yes.
        Also you can slot the mounting holes for additional caster. I did so and I have my car sitting at 10.2 degrees of caster as per last weekends alignment.
          • 34847
          how much further forward does it push them?
          I'd like to do THR brackets but with 235s it already rubs the inner fender liner up front - not too bad, but it touches them at full lock. if it goes too far forward it would be a problem though..
            • 37834
            I was thinking of slotting the OEM lollipops for adjustment.
            BimmerHeads.com
            • fronton
              • Oct 2009
              • 1262
              reviving this thread for more info as my driver side tire rubs slightly at the front and I have THR cabs.
              I need my wheel brought back about 3mm to cure all potential rubbing. I think non M3 centered bushings would solve but with my exhaust, I can't fit tennis rackets. Anyone have tips for removing a degree or two of castor from THR cabs?
              • rkettner
                • Jun 2007
                • 367
                I have a set of the treehouse cabs that i ordered without holes drilled. You could buy em off me and drill em if you like. PM.
                • fronton
                  • Oct 2009
                  • 1262
                  Do you remember how much you slotted the mounting holes? I am thinking just 2-3mm will do it.
