Rear from z3-m coupe
  • kuerone
    • 13
    Hey,
    To trailing arms from z3-m coupe/roadster i have to use half-shaft and differencial from this model?
    I look for different solution... Maybe this:
    differencial from e36m3 and half-shaft from e36m3.
    Ok but.
    Half-shafts from e36m3 - Maybe they are too short/long for trailing arms z3m- coupe/roadster.
    Hubs - If I use these from z3-m coupe/roadster they will be fit to half-shafts from e36m3?
    I thought also to put hubs from e36m3 to trailing arms from z3-m coupe/roadster (they have the same size of brakes) use half-shaft from e36m3 and differencial from e36m3.
    Very nice set ;)
    Someone did something like this? All will fit?
    Thanks for help!!
    Cheers
    Michael.
  • Dagamus(NM)
    • 618
    You need the whole rear end from the m-coupe with the e30 subframe.
    Gun control means using both hands
    Sex, Drugs, Rock 'n roll. Pick two.
      • 37829
      E36 M3 and M Coupe half shafts are the same. Also, the E36 M3 differential will not fit.
      Classic BMW Specialists
      Grover Beach, CA
      www.BimmerHeads.com
      • E30-323ti
        • 328
        You can use the E30 (188 ) diff, you need a pair of output flanges from an E28 to match the M-Coupe Axles.
        292rwhp E30 :D
        • kuerone
          • 13
          Ok, thanks guys. Helpful.
          Cheers,
