too much toe out
  • McGyver
    • 4636
    too much toe out
    Hey, i finished installing my 5-lug but i have too much toe out. i have the outer tie rods tightened as much as possible and the inner tie rods are in all the way too. what can be done to fix this? i need a new steering rack and inner tie rods right now and all that I can think of is to use one that is shorter from end to end.
    any other solutions out there?
  • McGyver
    • 4636
    just for clarification, this is what i am running:
    -e36m3 front struts
    -e30 front shock mount
    -e30 H&R Race springs
    -97+ e36m3 control arms
    -97+e36m3 spindles
    -e30 lollipop
    -offset e30m3 CAB
    since I have alot of caster (wheel is too far back), wouldn't that point the front of my wheel out resulting in too much toe?
    If my thinking is correct, to fix the caster (and as a result my toe out), I can either slot my lilipops or buy THR eyeball lollipops right?
    • rkettner
      • Jun 2007
      • 367
      I trimmed some of the outer tire rod threads off to allow them to come further in. There was way more threaded rod then needed in my case.
      I did it at the time with a 97m3 rack though. So your situation might be different.
      • McGyver
        • 4636
        well i plan to switch to a 2.7 lock to lock rack when blunt gets them in. it looks like it isnt bottoming out in the inner tie rod though. it looks like i ran out of thread on the outer tie rod.
        • Aptyp
          • 6584
          When I had a little "accident" my tie-rod joints were perfect, but outer tie-rod got stretched a little, and didn't allow proper adjustment by being too long. I got a new set, replace outers and everything went back to normal
