In for results! I would love to rock some old school SSR or something Jap as fuck. Only issue would be finding a front bearing that would match the rear pattern.
Subaru Hubs = E30 hubs?
Instagram: @BWeissLeather
Current cars:
~ '87 325 M30B35 swap
~ '87 535
~ 01 540 Msport 6spd
~ '06 X5 4.8is
I want some macho sauce! Sounds good.
OP, which E30 hub are comparing to the subaru hub? The only 57.1 dimension on the rear hub (which is splined like you mention) is wheel locating diameter. The ID is splined and the OD is like 42mm.
The front hub has no splines and i cant recall the ID that the bearing fits into cause you pretty much have to buy the hub and bearings together complete.
Any news on this? If the SVX hub fits, the the cheaper option would be to use an earlier model hub from an XT6. The XT6 is the prequel to the SVX and share the same suspension components like hubs, struts, springs, axles. I sure if this does in fact fit, the XT6 would be a cheaper option.
The front hub has no splines and i cant recall the ID that the bearing fits into cause you pretty much have to buy the hub and bearings together complete.Originally posted by 1craze30 View PostAny news on this? If the SVX hub fits, the the cheaper option would be to use an earlier model hub from an XT6. The XT6 is the prequel to the SVX and share the same suspension components like hubs, struts, springs, axles. I sure if this does in fact fit, the XT6 would be a cheaper option.
The OD of the bearing On the other hand is 75(e30), 72(svx). So the bearing Ultimately wouldn't fit.
I'm not stopping though. I'll digg around some more and see if there's a match!Last edited by Crodell6; 09-08-2012, 10:48 PM.
For all things 24v, check out Markert Motorworks!Originally posted by mbonanniI hate modded emtree, I hate modded cawrz, I hate jdm, I hate swag, I hate stanceyolokids, I hate bags (on cars), I hate stuff that is slowz, I hate tires.
I am a pursit now.
