possible cheap 5 lug
  • BahnE30
    • 1050
    i've been doing some thinking / research, i've been to a couple machine shops and they all say this is possible. remove 4 lug hubs, get them welded and re drilled 5X120, not a problem, the problem i think i'm going to run into is brakes. what will work. i was thinking of redrilling a rotor in the same fashion as above, but if there's another way, such as e30 M3 rotors if they work, i'm unsure, but if i can resolve my brake issues, i will be doing this... let me know what your think
    cheers
  • DEV0 E30
    • Oct 2004
    • 8892
    Shit's fucked up. Honestly it sounds like too much work, sourcing the parts really isn't that hard.
    • czag13
      • Mar 2006
      • 300
      sounds like a crappy job that'll end with a post in "Post your wrecked e30"... like devo e30 said, sourcing parts isnt hard, and if your gonna do it, do it right the first time... i dont know too much about 5 lug conversions but that's just my
      :(^SOLD^:(
      • np75
        • Apr 2006
        • 93
        I don't think it will work in the way that you think it will. I imagine that you are planning to only weld up the holes. I have read a spec sheet on the hub from one of the manufacturers, and I believe that it said that the OD of the flange is 120mm. The problem is that the five lug is on a 120mm bolt circle, so that half of every hole will be out in free air. Unless you are planning to build up the OD on the flange of course, which would be a bad idea on many levels (cost, strength, heat input into the bearings).
        • moatilliatta
          • 6151
          cheers
          them hub are hard as fuck. therefor it would take way lots of time to weld temper and then drill. and tap them.
          @Zakspeed_US
          • gazellebeigem3
            • Jun 2005
            • 3712
            so really you only want 5 lug for what? wheels?
            • BahnE30
              • 1050
              when you live in Butt fuck canada on the east coast where there's like 37 e30's in the entire province and you don't have ass loads of cash to spend on shipping suspension parts, you start looking for cheaper alternitives. and yes, i do really only want it for the wheels, i picked up a set of 17's motorsport reps for 300 bucks in mint shape, and i want to run them.
              • mattdk318i
                • Jun 2006
                • 3953
                ive been selling rears for 410 shipped. Then you could get some E36 struts and install some camber plates. Since you say there arent any E30s there.
