my 5 lug
  • DEV0 E30
    • Oct 2004
    • 8884
    #61
    You have to finish your 318 now with this stuff in a resondable amount of time you realize that right?
    You can't let all these people down.
    • Mr Deagle
      • 1121
      #62
      Originally posted by xLibelle
      this adapter, it goes on the inside of the strut hub body, right?
      Think of it as a sleeve, it goes over the spindle, and it makes it bigger to put an e36 hub over it
      ah 10-4
      • PiercedE30
        • Apr 2005
        • 4220
        #63
        make it 11 people now......
        My 2.9L Build!
        • matt
          • 3731
          #64
          Do you have pics of assembling the whole thing?
          I am concerned that it won't preload the wheel bearings properly.
          • Karlspackler
            • Jun 2006
            • 510
            #65
            I am in if you can figure out how to use this with the e36 ///m brakes front and rear.
            • StereoInstaller1
              GAS
              • 22679
              #66
              Deagle, when do we get to see a PRICE?!?!?!??
              We need to know what Rotors/calipers/saddles, etc., too.
              E36M3 would save a fuckload of hassle, especially if the saddles bolt on.
              Get on with it, man!
              Luke
              Closing SOON!
              Thanks for 10 years of fun!
              • Nick325is
                • 1409
                #67
                I would also be interested in these.
                -Nick
                • Mr Deagle
                  • 1121
                  #68
                  e36 rotors might work, but e36 spacing is different...but porsche calipers bolt right on
                  bearings will be able to be preloaded just fine, we build race cars, not lawnmowers
                  price will be under $100 for sleeve/nut
                  • xLibelle
                    • Aug 2004
                    • 2673
                    #69
                    you mean per set
                    • StereoInstaller1
                      GAS
                      • 22679
                      #70
                      So do you have a 300mm or so rotor? What caliper is gonna be the perfect fit, or are you going to make an adapter?
                      I wanna see Audi TT rotors and 750iL calipers, dammit!
                      Luke
                      Closing SOON!
                      • e304me
                        • Feb 2006
                        • 1374
                        #71
                        what size rotor will you use with the porsche calipers? what size wheels are needed? would e36 offset work?
                        • Mr Deagle
                          • 1121
                          #72
                          porsche rotors cost ALOT
                          im just making sleeves for me, and making my brakes fit...i dont really want to to the r&d with a cheap brake setup
                          do the 750i calipers bolt on?
                          you need lots of clearance for the porsche brakes
                          • StereoInstaller1
                            GAS
                            • 22679
                            #73
                            OK, so is the Audi the same lug spacing? PowerSlot rotors are available for about $160/pr. 300X12 with a 25mm backspacing, same as an E30 rotor.
                            The 750iL caliper would want to use a 25mm MC, but that is no big issue
                            300mm.de has a adapter that bolts on a 750iL caliper and passes TUV.
                            Funny I am so interested in this: I have no plans for a 5 lug.
                            Luke
                            Closing SOON!
                            • Mr Deagle
                              • 1121
                              #74
                              e30 non m caliper bracket center to center is 3.5 inch
                              find a caliper that is bigger and has a 3.5 inch center to center spacing, and you are all set, now you just need hats and rotors
                              • StereoInstaller1
                                GAS
                                • 22679
                                #75
                                OK, so if I read the translated German correctly, E34 540i saddles and calipers fit the E30M3 using 300mm X 28MM disks. Do you know if the E30M3 sadddles are the same spacing as the standard E30?
                                Closing SOON!
