my 5 lug
  • blueapplesoda
    • Dec 2005
    • 1904
    #91
    when will some be out? id be down right now to buy some, like this moment. then i can go figure out a brake setup.
    • Mr Deagle
      • 1121
      #92
      I might machine out a couple sets this weekend, I only have enough material for about 3 sets.
      • Rocla
        • 922
        #93
        I heard some rumors that with e36 hubs and a bit of machining you could keep your existing e30 abs, unlike the e28 setup that I'm working with.
        Current:
        BMW 320i 2d 2.0 m20 -88
        BMW 325i Cabriolet 2.5 m50 -88
        BMW 316i touring 1.6 m40 -90
        BMW 320i 4d 2,2 m54 -01
        • Mr Deagle
          • 1121
          #94
          this is true, from the looks of it it has the same abs ring pattern
          • Karlspackler
            • Jun 2006
            • 510
            #95
            well, I will buy one of the 3 sets.
            You said you have not gotten them figured out for the e36 m3 fronts. Well, does anyone know how big those are because I am only running 16" wheels. Maybe I hear the 330i E46 is a decent upgrade.
            What do you think?
            • Mr Deagle
              • 1121
              #96
              e30 has a different caliper center spacing than an e36, e36 brakes will not fit without adapters
              you need a caliper that has a 3.5 inch center to center spacing
              possibly<<<< z3 1.9 front rotors would work with your stock brakes >>>possibly
              • Rocla
                • 922
                #97
                I have no idea how, but one german builder used e30 M3 dics and 325i stock caliper.
                Unfortunately the picture does not reveal how the pads sit on the dics, but I'd say the pads don't come even near to the outer edge of the discs(which is bad?), the carrier must be modified heavily.
                Current:
                • Karlspackler
                  • Jun 2006
                  • 510
                  #98
                  So what rotor/caliper combo are you using?
                  • Mr Deagle
                    • 1121
                    #99
                    Im using porsche 930 brakes and rotors(2 piece) with custom hats
                    • Karlspackler
                      • Jun 2006
                      • 510
                      #100
                      Off the top of your head....
                      What caliper/rotor combo will work?
                      The e46 330i set up wont work?
                      Again, I honestly have NEVER worked on my brakes so I dont know their parts.
                      • Mr Deagle
                        • 1121
                        #101
                        stock brakes with possibly z3 1.9 front rotors, as i said <<<<maybe idk
                        nvm, z3 brakes are 26 mm bigger
                        • Karlspackler
                          • Jun 2006
                          • 510
                          #102
                          ok, so I cannot really get bigger brakes with your kit? I have to use the stock e30 brakes?
                          • Mr Deagle
                            • 1121
                            #103
                            you can do whatever you want, but it would be all custom
                            • Karlspackler
                              • Jun 2006
                              • 510
                              #104
                              ok, but can I still use your kit with different rotors?
                              • Mr Deagle
                                • 1121
                                #105
                                put it this way
                                you cant use factory e30 rotors with e36 hubs
