my 5 lug
  • xLibelle
    • Aug 2004
    • 2673
    #76
    Originally posted by Mr Deagle
    im just making sleeves for me, and making my brakes fit...i dont really want to to the r&d with a cheap brake setup
    seriously, dont waste your time with brakes. get those adapters made and the rest of the needed hardware will follow.
    • StereoInstaller1
      GAS
      • 22679
      #77
      Hey man...sorry I didn't catch that (good catch,xlibelle) I though you were trying to basically bring a 5 lug/BBK system to R3Vmarket.
      What needs to be done about the dust shield?
      Closing SOON!
      Thanks for 10 years of fun!
      • Rocla
        • 922
        #78
        OK, so if I read the translated German correctly, E34 540i saddles and calipers fit the E30M3 using 300mm X 28MM disks. Do you know if the E30M3 sadddles are the same spacing as the standard E30?
        If by the spacing you mean the distance between the bolts that attach carrier to strut, no.
        Suitable adapters fo e30 strut and e35 540i carrier are available from www.300mm.de.
        MB W124 500e brake discs can be mated to e36 or e28 hub with some machining.
        Current:
        BMW 320i 2d 2.0 m20 -88
        BMW 325i Cabriolet 2.5 m50 -88
        BMW 316i touring 1.6 m40 -90
        BMW 320i 4d 2,2 m54 -01
        • blueapplesoda
          • Dec 2005
          • 1904
          #79
          omg why didnt i see this before id be so down, like extra extra down for this too.
          • Karlspackler
            • Jun 2006
            • 510
            #80
            so how much for a set of 4?
            • Mr Deagle
              • 1121
              #81
              im only making the parts to adapt front hubs to e30 struts
              its a set of two
              unless you have 2 e30's
              you need e36 or e46 front hubs
              • asubimmer
                • 6482
                #82
                why not the rear's too?
                • DEV0 E30
                  • Oct 2004
                  • 8892
                  #83
                  E30 M3 hubs bolt directly to your trailing arms.
                  • Mr Deagle
                    • 1121
                    #84
                    I also belive early z3 stuff bolts on, and 318ti also bolts on to the rear (for a cheaper alternitive)
                    and e36 and e46 rears would work too, but i havent looked into that
                    • Karlspackler
                      • Jun 2006
                      • 510
                      #85
                      its a set of two
                      A set of 2? So 1 for each wheel correct??? 2 in each set?
                      What you should do Mr Deagle is put together a laundry list of what we need for us people who are not in the know that way we know what to buy.
                      I will buy your "spacers" ASAP if you get me the list
                      • Mr Deagle
                        • 1121
                        #86
                        I dont know what to do about brakes right now, i can only provide for the 5 lug
                        for the front, you need
                        my spacers
                        and e36/e46 front hubs
                        for the rear (im not sure right now)
                        318ti rear hubs and brake discs (that should give a working brake setup in the rear)
                        but dont go out buying stuff right now
                        • Karlspackler
                          • Jun 2006
                          • 510
                          #87
                          my spacers
                          Interesting. So you cannot use one of your spacers in the rear?
                          • Mr Deagle
                            • 1121
                            #88
                            you are missing the main thing
                            E30 E36 and E46 all share the same rear wheel bearings, hence 5 lug rear hubs from an e36 or e46 will fit with the correct axles, no spacer is nessicary
                            Mitch
                            • Karlspackler
                              • Jun 2006
                              • 510
                              #89
                              Mitch
                              Ahh ... IC. I can turn wrenches but stuff just needs to be spelled out for me. Thanks :drink:
                              • Mr Deagle
                                • 1121
                                #90
                                its all good
                                and i might be making splined spacers to fit z3m coupe rear hubs onto factory e30 driveshafts
