Share your 5 lug setup and wheels
This is a sticky topic.
  • BMWfanz
    • Dec 2013
    • 46
    #241
    Guys hello! I've used 1995 euro m3 spindles, 1996+ e36 m3 control arms and offset buschings but i think caster needs an increase, i think my wheel is slightly backside, or all is ok? look at photos plz)
    • Jpsteig425
      • Jul 2015
      • 11
      #242
      Looks great, I just did a similar swap except I used '97 M3 spindles.. I had the same caster issue..
      Ordered ground control camber / caster plates and it fixed all the caster problems
      '88 325i Cabrio - 5 Speed - Schwarz / Natur
      '88 325e Coupe - 5 Speed - Bronzit / Black
      '84 318i Coupe - 5 Speed - Bronzit / Grey Houndstooth
      '06 Mini Cooper S - 6 Speed -Hyper Blue / Black
      '98 4Runner - Supercharged - White / Tan
      • VBe30
        • Oct 2013
        • 173
        #243
        Front
        Nasieg Sleeve Kit - e46m3 Rotors/e36m3 Calipers
        Rear
        z4 Hubs with SRS concept caliper adapter for e46 non m caliper/rotor
        Complete
        e39 Style 32 with 205/40 front 215/40 rear Falken Azenis
        89' 325is - Alpine
        • ATL_E30
          • May 2017
          • 240
          #244
          Originally posted by VBe30
          Complete
          This car is my new inspiration, beautiful looking car!
          • wworm
            • Dec 2016
            • 1719
            #245
            Anyone running an e36 hub adapter sleeve and non m brakes? I love the look of 15's and 16's on an e30 and dont particularly need e36 m3 brakes. Would be stoked if a non-m e36 brake setup could be adapted.
            1984 Delphin 318i 2 door
            • jph
              • Feb 2015
              • 463
              #246
              Nasieg 5-lug fronts with E36 M3 hubs, E46 M3 rotors, and E36 M3 calipers.
              Z3M rear trailing arms with E36 M3 rear calipers and rotors.
              Front wheels are Apex Arc-8 17x8.5 et40 with Turner 17.5mm spacers.
              Rear wheels are Apex Arc-8 17x9.5 et35 with Turner 7.5 mm spacers.
              Tires are Toyo R888R 235/40 front and 275/40 rear.
              -1.6 degrees front camber, 1/32 toe in. -0.6 degrees rear camber, 0 toe.
              E30 Build by Jason H, on Flickr
              • LowR3V'in
                • 4209
                #247
                Complete
                Did you do this because a 225 would rub or you just like the look?
                What offset? i think i have the same rims 17x8 et20?
                • cocofunk
                  • Mar 2014
                  • 80
                  #248
                  SENSATIONAL! Exactly the setup I am headed for. PM'd you and local, must get some more info.
                  • alistairolsen
                    • Jul 2017
                    • 191
                    #249
                    Just how much arch work was required to get the 275s on the rear to fit?
                    Thanks
                    • jph
                      • Feb 2015
                      • 463
                      #250
                      Thanks
                      I want to say it ended up being around 1.25” wider than stock in the rear, or something pretty close to that.
                      • cocofunk
                        • Mar 2014
                        • 80
                        #251
                        ^^^ saw that car in person and met JPH. Dude is insane.
                        • jph
                          • Feb 2015
                          • 463
                          #252
                          potstir
                          • alistairolsen
                            • Jul 2017
                            • 191
                            #253
                            Thanks, was that just rolling/pulling, or did you end up adding metal?
                            • jph
                              • Feb 2015
                              • 463
                              #254
                              That was adding metal. All 4 corners have been worked over with new metal.
                              • alistairolsen
                                • Jul 2017
                                • 191
                                #255
                                Thanks for the info, lovely looking car!
