Share your 5 lug setup and wheels
This is a sticky topic.
  • bimmer630
    • 1228
    #211
    got the 16" e39 rims huh? never seen a set of those
    • Aptyp
      • 6584
      #212
      they are actually e38, so the hub bore is the same as e36
      • Wishno87
        • 6025
        #213
        Size and offset?
        Edit: Found information in another post. Thats going to look sweet though!
        • DTM190
          • Nov 2008
          • 1107
          #214
          E30 M3 5 lug
          Sitting on OZ Futura 17x8.5 et28 215/45-17
          No Anal prolapse here :p tight
          Originally posted by der affe
          first try a finger or 2, you need to have them suck on it first and get it nice and wet to help it slip in.
          if she goes for that, astroglide up your pole, have her lay on her stomach and slip it in slowly and bury it to your balls and leave it there until she relaxes. once she is used to it slam that ass like a screen door.
          • rich4rdee
            • 595
            #215
            Originally posted by Raxe
            '97 E36 M3 front, '99 M Coupe rear. 17x7 on 215/45/R17.
            love this! e90 328i wheels?
            • zenn0ne
              • Jan 2009
              • 119
              #216
              Hey guys here are some pics of an early dephin with full e30m3 5lug on style 32's staggered I had, until my stupid a$$ decided to go drinking one night and almost didn't make it home Click image for larger version
Name:	grey beamer.jpg
Name:	grey beamer 2.jpg
Name:	grey beamer 3.jpg
ID:	7127627 fyi the car made 447whp-440wtrq on a top mounted GT35R M52 with s50 cams and 140mls:crazy:
              sigpicBEST OF BOTH BOOSTED WORLDS
              • mohamadr89
                • 282
                #217
                i didnt do the my conversion yet but i have a wrecked 95 m3, what exactly can i swap over?
                mtech 2 325ic
                http://www.r3vlimited.com/board/pict...pictureid=7968
                check out my donut vid
                http://www.youtube.com/watch?v=Tw0paUP1FEQ
                • mscott
                  • Sep 2006
                  • 182
                  #218
                  my track car
                  ti rears and mix of e30 m3 and e28 front. E36 m3 brakes.
                  • Aptyp
                    • 6584
                    #219
                    40 lugs chillin' in Milwaukee
                    • IanS_in_Oz
                      • Jan 2010
                      • 75
                      #220
                      My track car... E36 5 lug, with M3 brakes
                      17 x 8 wheels, 215-45-17s
                      BumbleE30 M52 2.8i
                      • qccabrio
                        • Feb 2011
                        • 82
                        #221
                        I have a rear 5 lug set up for the e30, trailing arms, rotors, calipers, etc.... just bolt right up use your shocks and springs
                        Walter
                        602 540-3035
                        • nu-B
                          • 85
                          #222
                          What the white wheels on the gray car 3 up?^
                          • tonton
                            • Jan 2008
                            • 128
                            #223
                            rear:
                            orginal 4lug hubs, holes are welded up and drilled new 5lug
                            e30 325 std brakediscs (new 5x120 holes)and std calibers,
                            wheels 10"x17" et23 tires 245/35, all fits inside the fender, even if the camber is a bit corrected8-)
                            front:
                            e36 hubs with little modifications for abs sensor and std brakediscs
                            it require two spacers to fit, one behind and other to inner circle
                            then gauge change is as small as possible, 6mm total
                            std calibers need that 3mm spacers to fit with std brakedisc (new lug and enlarged center)
                            hope this help someone
                            I put the pics those front parts when I get all parts for myself
                            e30_cabrio_336[/URL]
                            • tonton
                              • Jan 2008
                              • 128
                              #224
                              tuplat
                              • canakami
                                • 743
                                #225
                                Who else wants brand new Genuine BMW E36 M3 front spindles for $50 A PIECE OMGWTFHS.
                                Always chasin'
