these wheels are now officially for sale, $250.
Share your 5 lug setup and wheels
This is a sticky topic.
my set up:
-Complete E30 M3 5lug suspension and brakes
-New E28 front wheel bearings (strong than stock)
-Aluminum front control arms
-THR CAB’s
-GC coilovers
-GC camber/caster plates
-GC rear shock mounts
-Koni top adjust shocks, front standard lenth
-AKG rear sub frame and control arm bushings
-S/S Teflon coated brake lines
-Sparco front strut bar
-Currently sitting on BBS RS 211 8jx16h ET11 w/ dunlop 215/45/16Comment
95 M3 front brake setup ( hub, spindle, caliper/carrier, rotors )
98 M3 control arms
Tree House Racing Eyeball
95 ti trailing arms ( trailing arm, hub, spindle, caliper/carrier, rotors )
GC 440/700 coilovers w/ camber plates ( e36 strut for e30 kit)
IE green sub frame bushing
IE street trailing arm bushing
98 M3 steering Rack
17" E46 325ci wheels ( had it laying around, will change later )
Turner Motorsports steering rack stopComment
Got bottlecaps on all 4 corners now, and it rides alot better than it did with 16's.. looks kinda cool too cause the wheel/tire assemblies are stuck farther out with the e36 offsetLast edited by bimmer630; 04-13-2009, 04:47 PM.Comment
come on, Atomic, bragging about using m3 parts, then telling us you're running spacers and high offset heavy wheels? Something isn't making sense. Why aren't you running proper wheels without spacers if you've already spent all that money on m3 parts?
PS: DS2's are incredibly heavy, why did you settle on those wheels?Comment
i'm pretty cornfused also. maybe he really likes 17's? i might be biased, but i think some 16x8 style 5's would be perrrfect.Comment
Oh and the DS2 wheels are likely sold (tires are already dismounted), so the style 66's, 42's and RKII's are where I am at now.
Not your damn car is it? No, didn't think so, so EAD... ;)
:drink:Last edited by atomic; 04-15-2009, 08:34 AM.Comment
/\ Did you roll your fenders flat?Comment
Front:
94325is knuckles and brakes, 97+ ca's, eyeball arms, GC coilovers with Vorschlag camber plates, slotted stock abs sensors.
Rear: 318ti ta's, IE rtab's and sfb's, IE weld in camber/toe adjusters, GC coil overs, TMS shock mounts, spacers for abs sensors.
BBS RKii, 17x8 et38 235/40 Goodyear f1 Asymetric:
Style 32, 15x7 et47, was 195/60 conti's, now painted black with 225/50 Toyo R888:
Your signature picture has been removed since it contained the Photobucket "upgrade your account" image.Comment
