Ballpark price for e36/MZ3 5-lug swap???(just parts)
  • george graves
    • 20003
    Subject says it all -
    My M30 swap is almost ready to roll, so I guess it's time to start a budget for the next project. Seeing that my front control arm busshings are shot - breaks need some attention and I am putting in a bigger motor I think a 5-lug swap would be in order.
    Has anyone budgeted with out using parts froma e36 m3 for the front and mz3 trailing arms in the rear?
    What is the best source for such parts?
    Thanks!
    George Graves
    Originally posted by Matt-B
  • Rigmaster
    • 3464
    Re: Ballpark price for e36/MZ3 5-lug swap???(just parts)
    My "Jordan" answer=
    you have not done ANY research on this, have you??
    I've NEVER heard of anyone using E36M3 parts for the fronts.
    Seems like this has been beat to death on this and other boards (it's a DAILY question on ROACHFLY), why rehash it here??
    Just my 0.02 scheckels.
    George Graves
    • Jon325i
      • 6934
      It really depends on where you get your parts from and what you get charged for them. I would say a really conservative estimate would be $1,500....but $2,000+ is probably a more reasonable figure (remember, you gotta buy wheels too).
      Jon
      Rides...
      1991 325i - sold :(
      2004 2WD Frontier King Cab
      RIP #17 Jules Bianchi
      • Jay Stock E30
        • 154
        My "Jordan" answer=
        why in the world couldn't you use e36 m3 parts for the front? Using standard e36 front knucles is common practice. E36 m3 stuff would work just the same, I', pretty sure that the steering knucles on an e36m3 and an mz3 are the same parts. Perhaps you shuld do your own research before telling somebody do to research. Last time I checked asking questions was a valid part of that research.
        I am sure that cost is totally dependent on where you get your parts, if you can get a deal, ect.
        • george graves
          • 20003
          ahhh - sorry for the somewhat re-post - I will do some more research - might even have to check out roadfly. Thanks...
          • UNHCLL
            • 8790
            ahhh - sorry for the somewhat re-post - I will do some more research - might even have to check out roachfly. Thanks...
            George -
            You can have E30 M3 bearings & hubs pressed into your existing 325i rear trailing arms. There, rear 5-lug is done. You'll have to modify brake plates and the e-brake mounts.
            Front : E36 M3 bolts up, you'll have excessive caster and positive camber. Search for the topic started by Eric Lukas (LukasBMW) I think... he explains his swap using e36 m3 parts.
            Below the radar...
            • george graves
              • 20003
              Thanks - yea, I've read that a bit.
              • Jand3rson
                • 37587
                Seriously? That's it for the rear?
                What has do be done on the front? (using E30 M3 parts)
                • UNHCLL
                  • 8790
                  Entire front struts. M3 specific.
                  Below the radar...
                  • Jand3rson
                    • 37587
                    Damn, that's so much easier than I've always been lead to believe. I guess the only hard part is getting the E30 M3 parts.
                    • george graves
                      • 20003
                      Ok - here a question - If I use e30 m3 parts up front - will e36 m3 10-spoke wheels fit perfectly - or will I still need spacers fill out the wheel wells???
                      Or a more general question - will wheels be positioned different on a e30 m3 5-lug swap than on a e36 m3 5-lug swap - OFFSET WISE....(not front to rear)
                      thanks!
                      • UNHCLL
                        • 8790
                        I *think* the e36 setup will put the wheels further out in the fender wells.
                        I am not positive though.
                        Below the radar...
                        • Jand3rson
                          • 37587
                          Dammit, there was a guy at the NW E30 Picnic that was selling the front strut assemblies and rear hubs for an E30 M3, I should have bought them. I had the money...
                          • Digitalwave
                            is a poseur
                            • 6302
                            And no car to put them on! :) Buy the car, THEN mod it...
                            RISING EDGE
                            • Jand3rson
                              • 37587
                              You mean I can't do it the other way around?
                              I know what you are saying TJ, it's one of those things that would have been good to buy and save.
