Best camber plates for someone on a budget....
  • Avus_325is
    • Mar 2004
    • 446
    I really need to find something that will preserve the tires a bit more now that I have a half hour one way commute and am driving 5 times the distance I use to a day. Just looking for a fixed plate design that will take out as much camber as possible. I suppose anything a 1/2* or more would be great.
  • Digitalwave
    is a poseur
    • 6292
    Well, most aftermarket camber plates are made to increase negative camber, not positive. But I am sure you can add some positive with them. You might want to look into getting the BMW OE crash correction mounts. They are just like stock, but depending on how you install them you can get 1/2 degree positive or negative added.
    RISING EDGE
    • Ben Carufel
      • Jun 2004
      • 5248
      Ireland Engineering sells something. www.bmw2002.com
      I think their $150 plates will work for you.
      • Charlie
        kid tested, administrator approved
        • 6686
        Re: Best camber plates for someone on a budget....
        BMW OEM crash mounts. You can flip them to gain postive camber.
        -Charlie
        Swing wild, brake later, don't apologize.
        '89 324d, '76 02, '98 318ti, '03 Z4, '07 MCS, '07 F800s - Bonafide BMW elitist prick.
        FYYFF
        • Mystikal
          Wheel Fitment Expert
          • 9602
          Exactly how negative is your camber? Even with my car slammed this year, my Azenis wore from new to all the way bald completely even.
          • bmwm3n528
            • 3654
            There's a guy in Roundel that sells some for like just over $100...just ordered some from him.
            Stainless steel, and they're adjustable.
            Trevor Ely
            '95 M Sport 540i - '00 A4 1.8TQMS - '85 190E 2.3-16
            '88 535is - '87 325e - '89 325is - '91 318is - '90 325is - '96 328is
            • Digitalwave
              is a poseur
              • 6292
              Forgot about those; $130 and they are adjustable.
              RISING EDGE
              • Charlie
                • 6686
                http://www.bmwbushings.com/BMW%20Camber%20Plates.htm
                I don't think you can get any positive camber with those, which is what this guy needs.
                I'd still say that the crash mounts are his best bet.
                -Charlie
                FYYFF
                • Avus_325is
                  • Mar 2004
                  • 446
                  Thanks guys. The camber isn't terrible but enough so that the wear isn't even. I figure I fix that I'll only be replacing 2 tires (rear) every 8 months.
                  • DanGillan
                    • Mar 2004
                    • 4061
                    my solution to your problem (i had the same problem) was, i bought the correction upper strut bearings to add 1/2 a degree of positive, and then i bought the IE street camber plates which can add a 1/2 or subtract 2.5, i added a half, so im now back to stock camber, and i also have the option of going to -3.5 for a track day. its a nice set up in my opinion
                    Dan
                    • Brew
                      • 3060
                      -Charlie
                      Anybody have a part #?
                      TIA
                      '91 318is
                      • Charlie
                        • 6686
                        -Charlie
                        TIA
                        I can't dig up a part number on the ETK for the offset mount. However, shops like Bimmerworld carry them, and I'm sure if you walked up to the dealer and asked for "offset strut top, aka crash mounts", they'd know what you were asking for.
                        -Charlie
                        FYYFF
                        • Brew
                          • 3060
                          -Charlie
                          TIA
                          -Charlie
                          Yeah, I couldn't find it on the ETK. I'll most likely go to the dealer.
                          Approx. price?
                          '91 318is
                          • Charlie
                            • 6686
                            -Charlie
                            TIA
                            -Charlie
                            Approx. price?
                            Bimmerworld asks 89/piece for them. I'd give BMA or a place like that a call, see if they stock it as well.
                            -Charlie
                            FYYFF
                            • Avus_325is
                              • Mar 2004
                              • 446
                              Yea, I checked out bimmerworld and was blown away by 89 a pop. I got a buddy down in rockville that works at a dealer, deffinately gonna have to give him a call, hopefully I could find something in the 100 range.
