Vibration in steering wheel
  • Wes325
    • 563
    Under braking only my steering wheel will begin to shake and almost have
    something of a faint knocking sound. I don't think that this is due to a warped
    rotor. I am going to take a shot at solving this.
    Would it be my control arm bushings?? I believe these are not too difficult to
    replace either. Could someone please shed some light on this. Thanks.
    - 318is 4 life
  • Rob
    • 8166
    have your wheels recently been balanced? why dont you think its your rotors? if its not those two, it must be a bushing, i guess the CA
    BEERTECH
    • Wes325
      • 563
      I dont see why having the wheels balanced would solve my problem under braking.
      Would warped rotors cause the steering wheel to vibrate hard? The reason im hoping its not the rotors is because I just had a brand new set in my garage and I just sold them :x
      - 318is 4 life
      • Rob
        • 8166
        unbalanced wheels can have effects in many ways, not just highway cruising or whatever. the effects of unbalanced fronts could be exaggerated under braking. my e30 had all sorts of wierd wiggles and wobbles until i put a set of freshly balanced wheels on
        "Would warped rotors cause the steering wheel to vibrate hard?"
        yes
        BEERTECH
        • e30Matt
          • 5077
          Sounds more like a rotor problem.
          • TimmyBigHands
            • 260
            Yeah, that definetly sounds like rotors. I'm replacing mine this weekend. Hopefully my steering wheel shakes go away too.
            • BE30s
              • 85
              I had the same problem even after replacing my rotors, turned out to be the ball joints.
              • Gus
                • Jan 2004
                • 285
                sounds exactly same as me....mine was my control arm balljoints...very loose
                JUNGL3
                1990 "333i" Sport
                • Digitalwave
                  is a poseur
                  • 6302
                  Well I had the same problem and I replaced my rotors and CAB's at the same time, so I am not sure which it was. But the problem is usually pad deposits left on the rotors, they usually aren't actually warped. If they have enough meat left, trying having them resurfaced.
                  RISING EDGE
                  • Brew
                    • 3060
                    I had the same problem on my old e30 and it turned out to be the control arms and bushings. I'm sure you can pretty easily check for play in any of the ball joints
                    '91 318is
                    • Wes325
                      • 563
                      haha. damn it, becaue it is a toss up right now for what I'm going to get. I think I'm just going to get them resurfaced(cheaper). Man I wish I still had access to my auto tech classes brake turning machine.
                      - 318is 4 life
                      • bmwm3n528
                        • 3654
                        Mine has ended up being almost entirely CAB related...with only very little of it being attributed to a slightly warp in the front rotors.
                        Trevor Ely
                        '95 M Sport 540i - '00 A4 1.8TQMS - '85 190E 2.3-16
                        '88 535is - '87 325e - '89 325is - '91 318is - '90 325is - '96 328is
                        • Wes325
                          • 563
                          Is there a way to check to see if it is the CABs before I go order some? If not, they are not too pricey.
                          - 318is 4 life
                          • BimmerKris
                            • Aug 2004
                            • 116
                            the control arm bushings for sure. mine went, but never had any problems with the brakes. it's kind of a pain in the ass if you don't have a decent press.
