Metallic rattling noise up front
  • Avus_325is
    • Mar 2004
    • 446
    Recently there has been a pretty loud clanking noise that seems to be coming from the front passenger's side every once in awhile when I hit a bump. It's completely random when it happens, like it's not only with big bumps or only small ones. I had thought that it was the wheel bearing which needed replacing anyway but after I did that the noise is still there. I checked out all the ball joints and tie rod ends and they are all in pretty good shape so i'm stumped.
    Also I have a nasty shimmy up front after replacing the wheel bearing, i'm thinking it's the rotor or caliper.
    Any ideals would be appriciated.
  • randomtask37
    • 3154
    do u have spring pads?
    98 M3/4/5
    • Avus_325is
      • Mar 2004
      • 446
      Yea I still have the spring pads in. It's much louder than just a metal rubbing though.
      • Digitalwave
        is a poseur
        • 6299
        Check the collar that holds the strut into the strut tube. When mine loosen they rattle a bit.
        RISING EDGE
