Lots of annoying clunking.
  • Kruzen
    • Mar 2004
    • 5603
    At low speeds when shifting i can hear some clunking coming from the rear, it is also just some general clunking when going over bumps, etc.
    can anyone guess what is causing this? i'm pretty sure my suspension is just plain shot, i actually wanna redo the whole front end and rear stuff.. can i get a shopping list plz?
    edit: jack is secure, and i'm pretty sure my spare is secure as well.
    Who doesn't love a little BBQ?
    Griot's Garage at a Deep Discount
  • randomtask37
    • 3154
    sounds like your diff bushing could be shot.
    98 M3/4/5
    • Bill 84 318i
      • 1600
      I'd blame the clunking noise on your subframe bushings/diff bushing.
      Complete list of stuff to replace:
      Front:
      Control arms
      Control arm bushings (M3 offset rubber bushings are a good upgrade)
      Tie rod assemblies
      Upper strut mounts
      Sway bar bushings and links
      Rear:
      Subframe bushings
      Trailing arm bushings
      Differential bushing
      Rear shock mounts
      Lemfoerder is known to be one of the best brands for OEM parts.
      • Kruzen
        • Mar 2004
        • 5603
        Front:
        Control arms
        Tie rod assemblies
        Upper strut mounts
        Rear:
        Subframe bushings
        Rear shock mounts
        Also, the little rubber boot on my steering rack is very slowly leaking red fluid (front right).. The boot's been turn in half by something, (but looks fairly clean cut, so it might have been the previous owner?) I guess now would be a good time for a m3 steering rack or somethign?
          • 34844
          the red stuff is ATF.. and it's not supposed to be in the boots. your seals are leaking, and your rack needs rebuilt. if it's not too bad you can probably just use some stopleak on it for a while. the boots are just to keep dust out..
          • Kruzen
            • Mar 2004
            • 5603
            where can i get some of this magical stopleak, and where should it be applied to specifically? I'm not quite sure the best way to locate the leak.
            • mjc85
              • Mar 2004
              • 164
              I am almost definate that the clunking is your top rear strut bushing. After time they compress and lose there elasticity. Pull out the boot lining and have a look if it is them.
              I had the same problem bugged me for ages before i bothered to look, if you dont get around to it you can seriously injure where your rear struts mount in the boot.
              1990 318is Brilliantrot
              • e30Matt
                • 5077
                Check your diff mounting bolts as well... mine was making some strange noises, and it turned out the front two were missing. Heh, I guess that's what I get for running stiff-ass suspension.
