Girling vs ATE
  • dlmrun2002
    • Apr 2007
    • 808
    Girling vs ATE
    Does it really matter what calipers are on the front or back? Obviously, you want a matching pair in the front and in the back but can I run Girlling up front and Ate in the back or visa versa? Thanks dlm 1991 318is (coming back to life).
  • digger
    • Nov 2005
    • 6173
    if piston sizes are same between each brand which is surely the case then wont matter just have the fronts the same and rears the same with all associated brackets to mount to knuckle etc.
    • Vincenze
      • Apr 2019
      • 1032
      All rear disk brakes were made by ATE.
      I don't know about drum brakes.
      • roguetoaster
        Biggus Tippus
        • 7830
        As an axle set it seems to make no real difference from a performance standpoint. Clearly, racers used to prefer the ATE fronts since there are/were solid bushing kits available.
        That said, I'd bet that there is some difference in clamping load curves between the two manufacturers, so having on ATE and one Girling on the front could potentially cause the car to brake steer in normal operation.
        • dlmrun2002
          • Apr 2007
          • 808
          Yeah I wouldn't run different manufacturers on the same axles( front or rear). Gotta get in there and do the whole brake system over once the weather breaks since my garage is cold as hell. dlm ny county
          • roguetoaster
            Biggus Tippus
            • 7830
            Can't do different mfrs on the rear axle, as mentioned ATE only.
            • digger
              • Nov 2005
              • 6173
              come to think of it mine were girling front and ate rears but have since ditched the girlings
