I'm looking at getting some Goodridge brake and clutch lines for my E30 318i off of ebay and I'm wondering, is it worth it? I'm looking to get better feel and response from my brakes and also my clutch.
Are braided SS lines worth the upgrade?
Tags: None
SS lines wont changed the feel as much as you are expecting.** Lot's of M20 turbo parts for sale.**
Turn key track car.
http://www.r3vlimited.com/board/showthread.php?t=222066 -
I kinda got those responses from some other friends I asked after posting this thread too.
Guess it's probably more worthwhile for me to look at replacing my rear drums with discs first haha. I don't track this car, it's just my DD.Comment
www.gutenparts.com
The rubber lines last longer than SS ones? I was under the impression that if the SS lines had a protective plastic coating or something over the braids (to prevent dirt from getting in to abrade the inner tubing as the braid moves) then they would be just as durable.Comment
The rubber lines last longer than SS ones? I was under the impression that if the SS lines had a protective plastic coating or something over the braids (to prevent dirt from getting in to abrade the inner tubing as the braid moves) then they would be just as durable.///Alpinweiß II 24v 91' 318is, Alpinweiß III 99' 323i, 04' Yamaha R6 SE for sale, 00' VW GTi, 83' El Camino BURNED, 01' P71sold, 92' Miatasold
if it ain't broke, don't fix it.
seriously, I wish I would have left my IE SS lines alone. I replaced them with UUC lines, which are way too long, and now I have zip ties and all sorts of contraptions to keep them from rubbing on my front tires.
the difference in pedal feel is negligable. It won't hurt, but if there's nothing wrong with your old lines, you can skip the pain of replacing them, especially the ones above the rear subframe.
Unless of course you get one of the 4 line kits (like Goodrich?) but then you have 4 SS lines and 2 OEM rubber lines...Comment
I just went with SS lines because they were the same price and I figured it couldn't hurt with all of the autoX and the few HPDE events my car sees. Can't really tell a difference, though.Comment
OK, so I guess this is one of those things you only do when you have to replace your old lines.
nando: If I get a 6 line kit, I will still only be using 4 lines since my rears are drums. Although as mentioned, I might probably look at getting discs sometime later.Comment
all I know is the IE lines they replaced were a good 2" shorter. they also fit perfectly..Comment
When I ordered the SS from UUC the fronts were very long. They were the wrong ones, call them up and they will send you new ones.Alex 88 m5 | 91 318is | 19 Subaru Ascent
BMW Tool Rentals & Fender RollerComment
