IE TABs are squeaking
  • kencopperwheat
    King of Kegstands
    • 14396
    Is it the bushing squeaking on the TA? Or the bolt on the sleeve?
    Originally posted by Gruelius
  • BenM
    • 2184
    I think its the bolt on the sleeve. My dad had a similar issue on his car with the powerflex TABs and some marine wheel bearing grease solved it.
    Originally posted by BillBrasky
    E36's are the Stephen Baldwin of the 3 series family. They barely hold everything together and they only sold a lot because of the popularity of their older sibling.
    1991 318i Alpine II - S50/5-lug swapped - track car
    1989 325i Cirrusblau - Daily
    1970 2500 - Malaga over Grey Cloth
    2012 F350 6.7PSD
    • Stephen
      Шлем ишака
      • 10774
      i believe bushing on the sleave, i know its common, and remedied by l00b
      • kencopperwheat
        King of Kegstands
        • 14396
        You mean bolt and bushing sleeve? You can't lube between the bushing and bushing sleeve.
        • Stephen
          Шлем ишака
          • 10774
          Oops , yes thats what i meant. A freind of mine used to work at IE, says they take more lube than they give you
          • BenM
            • 2184
            Ken, do you by any chance have larger sway bars? Just talked with my dad and he said it was actually the ST Rear sway bar mount making noise. Maybe check that, or even the stock mounts if they are fresh.
            So i guess disregard what I said before.
            2012 F350 6.7PSD
            • kencopperwheat
              King of Kegstands
              • 14396
              No, stock rear bar with all recent bushings.
              Definitely the TABs squeaking.
              • E30_fiend
                • Apr 2006
                • 7348
                the noise is the bushing itself rubbing inside the trailing arm sleave. You obviously didnt use enough lube when installing them. Mine hardly make a noise and I used copperized grease. They will make noise very rarely but its tolerable. It sucks but if you dont like the noise you need to re-grease them.
                Taylor
                • hoveringuy
                  • Dec 2005
                  • 2751
                  Reviving an old thread...
                  Why aren't urethane trailing arm bushings a press-fit like OEM? I don't understand why they need to be lubed between the bushing and the the trailing arm bore to start with, isn't the suspension pivoting at the bolt/bolt sleeve interface??
                  • KenC
                    King of Kegstands
                    • 14396
                    They're not as tight of a fit as the rubber OEM ones bc you can't compress urethane like that. They just slide into the TA by hand.
                    BTW mine still squeak.
                      The motion will be between the sleeve and bushing. When the bolts are tight the sleeve will be locked to the trailing arm mounts on the subframe.
                      • hoveringuy
                        • Dec 2005
                        • 2751
                        Anyone ever waffleswaffleswaffles zerks on the trailing arms?
                        Where's the best place to put it?
                        I'm leaning towards going with urethane, just want some insurance against squeaking...
