Poly Bushings - IE or AKG
  • themitchster359
    • 654
    My shop told me that my rear subframe bushings are shot to shit, and that they need replacing. The rubber is almost none existance, and I can't even get on the car without the rearend flopping all over the place.
    I have read a little bit about replacing them with ploy mounts. I am just gonna replace the subframe and trailing arms as well. What brand would you guys prefer....IE or AKG?
    Also, if I choose AKG, what hardness? Would my car feel stiff as a rock with the 75d in the rear??
    Thanks.
    89 Alpine White e30 325i
  • whiltebeitel
    • Apr 2007
    • 2098
    I'd lean towards AKG myself, not based on any real hard data, but just from handling IE and AKG parts. After riding in a car with polyurethane bushing in the back, it's not harsh, just connected. The rear is much more communicative.
    '89 325i track sloot
    '01 530i daily
    -Enginerd
      • 34839
      the AKG 70a bushings are softer than IE "green" subframe bushings, FYI.
      75D is pretty well solid. If it's mostly a track/fun car I don't think it would be a problem, but otherwise I would go for the 70a or the IE greens as a compromise.
      • themitchster359
        • 654
        do you know what hardness you have with akg?
        • themitchster359
          • 654
          fyi, i do autocross my car about 6 times a yr...and i don't necessarily mind a stiffer feel, but i dont want my car buzzing like crazy...
          • Aptyp
            • 6584
            From experience, IE.
            Had a thread going on all of this. http://www.r3vlimited.com/board/showthread.php?t=133400
            • Aptyp
              • 6584
              Oh and if you want, I have PowerFlex subframe mounts and diff mount left over. Brand new, in pouches. I was planning to put it up for sale soon. $140 plus shipping and they're shipped to you.
                • 34839
                then you'd want AKG 70a (softest) or IE. 75D is nearly solid like I said.
                • slow e30
                  • Jul 2009
                  • 398
                  what exactly is a "fun"car? i drive mine MAYBE 3 times a week... and when i do, oh baby i make it feel like a racecar. (red-line on the onramps, floor it through the no speedlimit area nearby and occasional soso drifto fun. so the 75a should be a good setup?
                  • themitchster359
                    • 654
                    lol, well i daily it every freaking day, i have driven it 23k in one yr. i think im gonna go ie or bma. akg seems alittle much for me.
                    • themitchster359
                      • 654
                      what's the rating on your bushings? i might consider...wha'ts the lifeline on these? i don't want this shit hardening up after 2-3 yrs.
                      • NC325iC
                        • Mar 2004
                        • 6565
                        i have ie suspension bushings and they seem to be fine
                        BUT their trans and likely motor mounts i dont like, they dont clean the urethane froom the threads before they send them to you, ive had 2 of the plates inside the uretane brake loose so ive had to cut the nuts off. just not good imo
                        • Aptyp
                          • 6584
                          Subframe ones are 95A. They are very stiff, but I am having no issues daily driving it for quite some time now, I haven't taken car to any sporting events since I put them on.
                          I have IE motor and trans mounts, they haven't broken yet, but now I am worried.
                          • themitchster359
                            • 654
                            im gonna go with a different brand when it come to motor tranny mounts. man, this is a hard decision!
                            • whiltebeitel
                              • Apr 2007
                              • 2098
                              Support the Vorshalg guys in Dallas with the engine mounts! ;)
                              '01 530i daily
                              -Enginerd
