Poly Bushings - IE or AKG
  • themitchster359
    • 654
    Originally posted by whiltebeitel
    Support the Vorshalg guys in Dallas with the engine mounts! ;)
    arent they retarded expensive?
    89 Alpine White e30 325i
    • GotCone?
      • Jan 2008
      • 589
      I've had PF & AKG. Unless your tracking/hardcore. Get the Powerflex ones hands down. PF install easier as well.
      I like the AKG's a lot though.
      Build : Das Drehmoment Ungeheuer
      • Gnarles
        • Dec 2008
        • 342
        I have the AKG 70A subframe bushings and 75D trailing arm bushings. No complaints so far. Had them on for about 8 months now.
        • StereoInstaller1
          GAS
          • 22679
          I did urethane TA bushings, but stock SF and diffy mounts.
          Firmer, a tiny bit harsher, but well worth it.
          Closing SOON!
          Thanks for 10 years of fun!
          • üblemaschine
            • Jul 2009
            • 29
            I have used AKG subframe, diff, trailing arm, motor mounts, trans mounts, and LCABs on my old E30 and my E36. Used 75d on both as they both were/are auto-x cars and NVH wasn't an issue. Never have had a problem with them. They make a huge difference in the stability of the car (especially if you are replacing substantially worn parts.)
            Past-Flat Black '86 325,Schwartz '89 325iS, Lagunagrun '91 318i, 92 318i, Schwartz II Supercharged '97 328i, Luftwaffe '91 318iS Rallycar
            -Current- Alpinweiss '91 318iS (under the knife after slaughtering a deer), Luftwaffe '91 318i Rally Car (in progress)
            • aworthybrother
              • May 2007
              • 899
              installed IE subframe and TA poly bushings on my previous car and it squeaks.
              • Gnarles
                • Dec 2008
                • 342
                should have used more lube when installing them.
                  • 34839
                  yeah, I've had IE TA bushings since 2003 without a single sqeak.
                  • slow e30
                    • Jul 2009
                    • 398
                    is there a one stop shop where someone can get all upgraded bushings for a e30? i dont really wana piece together a rainbow of colors under my car from different companies.
                    • Aptyp
                      • 6584
                      PF and IE both have full lines of urethane. So do AKG.
                      I like rainbows, but by some freak of nature, all my bushings under the car are now red and match my H&Rs. I guess if I was to run over someone, and they liked color red, they'd be aesthetically pleased.
                      • themitchster359
                        • 654
                        lol, i don't think they'll fit :)
                        • johnwoo
                          • Oct 2007
                          • 613
                          i have some ie rtab that i would let go for cheap. im in oklahoma and shipping wouldn't be too bad.
                          im going to go with the akg because of quality and all my other ones are akg
                          • themitchster359
                            • 654
                            are they the two piece or the older single piece? also, what are they the green or red? thanks.
                            • BUDNUNTA
                              • Apr 2005
                              • 996
                              I just put the AKG 75ds in my car and its kind of "creeky"
                              Its hard to explain it doesnt squeek but makes this noise when you take off sometimes or go over bumps slowly. I had the IE Street Subframe ones in my old car with BMP TA bushings and they sounded pefect. Im not really happy with the AKG ones at the moment but ill give them a few more miles before I make a decision. Maybe ill take them apart and relube them when I have it apart again.
                              Hunter
                              We're out there in here.
                              • johnwoo
                                • Oct 2007
                                • 613
                                two piece and they are black
