What brake setup are you currently running?? Favorite setup?
  • RCWells
    • 3589
    I have already ordered mine so I am not looking for opinions on what I should buy. I'm just wondering what setup you are using, and whether you would repeat it when time to replace? Or, in your experience, what setup has been your favorite?
    My setup:
    Front- ATE power disc / Axxis Ultimates
    Rear- Brembo / Axxis Ulitmates
    Stainless steel brake lines
    Motul 600 fluid
    The rotors/pads/fluid will all be new for me. I will give my feedback on my setup later.
    [THE 501 club - Founding Member]
  • BahnE30
    • 1050
    Stock Rotors, PBR Ceramic's all way around and SS brake lines, with the above mentioned motul
    • RCWells
      • 3589
      Are the PBR ceramics and the Axxis ulimate the same pad?
      • BimmerToad
        • Sep 2004
        • 1537
        I believe they are.
        San Diego BMW repair -> Jake @ www.littlecarshop.com Great guy :up:
        • RCWells
          • 3589
          You guys are no fun. Doesn't anybody want to play along? Just what brake setup you have...it's not that hard.
          • Brew
            • 3060
            Front: ATE slotted rotors/ Mintex "Red box" pads
            Rear: OE Brembo rotors/ Mintex "Red box" pads
            Ireland Engineering S.S. braided brake lines.
            Pedal is nice and firm and, with the 320 booster, not overly assisted at all. I haven't experienced any fade, but I haven't yet been to the track.
            Overall, I'm happy with the setup so far.
            '91 318is
            • Mike 91 318ic
              • Jun 2004
              • 429
              100% stock dealer installed... By far the best brakes I've had in the car... They stop on a dime, and are 100% silent. I'll never use after market brakes again...
              M
              • ViEtNaMeeH
                • Aug 2004
                • 111
                ummm can u guys post how much u guys spent too ...i need to replace my brakes and wondering how much i should save up
                • Jon325i
                  • 6934
                  Ok...ok.....I'll play too :P
                  Car: 1991 325i
                  Front brakes: ATE PowerDiscs w/ OEM pads
                  Rear brakes: stock rotors w/ OEM pads
                  Rubber lines and cheap fluid
                  I just purchased this car in early Nov. and nothing needed to be addressed since it was all in very good working order. Eventually things will be upgraded as time warrants.
                  Jon
                  Rides...
                  1991 325i - sold :(
                  2004 2WD Frontier King Cab
                  RIP #17 Jules Bianchi
                  • James Crivellone
                    Head Janitor
                    • 6305
                    Front Pads = OEM
                    Front Rotors = OEM
                    Rear Pads = OEM
                    Rear Rotors = OEM
                    Stainless Steel Brakelines
                    25mm 750IL Master Cylinder
                    ATE Super Blue Fluid.
                    M3 ABS Computer
                    • BimmerToad
                      • Sep 2004
                      • 1537
                      Currently I'm running:
                      Front: OEM calipers, rotors (10in) and Mintex red pads
                      Rear: OEM E30M3 calipers, rotors (11in) and OEM pads
                      ATE Superblue fluid, new rubber brake lines (except for the front) and the 750iL 25mm Master Cylinder.
                      • Cone
                        • 135
                        I have stock rotors front and back, and I have Hawk HPS pads front and back. I also have a 25mm BMC and ss brake lines with the super blue fluid.
                        On the track with my stock brakes, they faded really bad, I never got them to fade on the street though.
                        I haven't taken my current setup to the track yet, but I also got brake ducts, so they'd probably work a lot better.
                        The Hawks don't work as well as stock when cold, but when they're warmed up after some spirited driving, they work really well.
                          • 34844
                          okay I give in, here's my setup (nothing special)
                          front:
                          ATE powerdisk rotors, Pagid pads (non-sport)
                          rear:
                          stock rotors, pagids
                          SS lines, ATE fluid. new calipers on all 4 wheels (well, new as of 20k on the rear and 40k on the front)
                          I have 20k on these brakes now, almost due for new pads & flush. Probably not so great for track use, but on the street they have great bite and I've never faded them, even when dropping the anchor at 100+.
                          The bite was always the most impressive part, I once accidentally chirped my tires at 70mph when brake checking a tailgating moron (barely even tapped the brakes, just enough to make the light come on). it scared the shit out of him though!
                          I want to try a more agressive pad next time, although these are definetly liveable on the street! only bad part: dust up the kazoo.
                          • Charlie
                            kid tested, administrator approved
                            • 6686
                            OEM calipers, Hawk HP+'s front, HPS's rear. SS lines, Superblue/Typ 200 fluid (alternate every flush - roughly every 3 months). OEM rotors, can't beat the price.
                            Gonna be stepping up to Hawk Blues/Ctechs for track usage this year.
                            -Charlie
                            Swing wild, brake later, don't apologize.
                            '89 324d, '76 02, '98 318ti, '03 Z4, '07 MCS, '07 F800s - Bonafide BMW elitist prick.
                            FYYFF
                            • Brew
                              • 3060
                              You guys who are running Dot 5/ Superblue- did you find that the Dot 4 was not up to track use or are you just playing it safe?
                              '91 318is
