Acura Big Brakes on the E30!!!
  • OneNutBandit
    • Nov 2009
    • 48
    Just got done putting on a set of 94-00 acura integra calipers and 11" AEM Slotted Rotors.
    Why?
    Bigger Aluminum calipers, bigger piston, weigh half of the origonals, and cheaper and bigger pads.
    Now to pics.
    First had to grind just a little to fit the hub.
    test fit of the rotor.
    Acura Caliper with the brackets that came with rotors.
    Had to weld on some more aluminum to reach the hub.
    Drilled and tapped the brackets to bolt on!
    All together with Caliper and Rotor. Oh and the Bmw brake line threads right into the Acura caliper.
    Wheel on and they fit perfect. Oh i had to grind on the knuckler of the Steering arm about an 1/8 of and inch to clear rotor, nothing major.
    All together on this i spent..........30 bucks for the calipers at the junk yard! I had the rotors and brackets laying around that a friend gave me.
    They work amazing. Firm but not too firm pedal, and not touchy, if you want more brake, you just push on the pedal more without it suddenly locking up. Love them.
  • b*saint
    • 3794
    Integra brakes arent that big tho.
    Ma che cazzo state dicendo? :|
    • kishg
      • Sep 2006
      • 2624
      why did you need bigger brakes?
      '12 F30 328i Sport Line
      '91 SpecE30 #523
      '00 Ford F-350 Dually Tow Vehicle
      BMWCCA #360858 NASA #
      128290
      • White325is
        • Oct 2006
        • 5947
        To stop them bigger wheels yo.
        • Hellabad
          • 807
          See if you can bolt on the caliper from an Accord with ABS. It might bolt right up, and uses a huge pad.
          Jay from GC
          Here is my photo gallery answering common questions about Ground Control Suspension, and e30 suspension problems in general.
          Ground Control Gallery
          The Ground Control facebook page: Dragged, kicking and screaming into social media to see what happens next.
          • chau
            • Aug 2009
            • 55
            on such a light car, don't you run the risk of the wheels locking up under braking? Without the abs that is.
            • !kid
              • 1362
              i would not use aluminum for brackets for fear of cracking just my 2 cents
              :borg:
              • Wh33lhop
                • 11705
                Think about what you just said.
                Now go sit in the corner.
                paint sucks
                • Holland
                  • Nov 2008
                  • 7212
                  That's not what my brakes told me the other week.
                  Originally posted by DEV0 E30
                  • NC325iC
                    • Mar 2004
                    • 6565
                    i hope there were more steps than that, like measuring, and i hope the drilling took place on an end mill.
                    if no to both of those, R3v thread coming soon
                    "my brakes fell off..."
                    • OneNutBandit
                      • Nov 2009
                      • 48
                      I did a shit ton of measuring and re measuring and they are NOT going to fall off i gaurantee. And this is why i needed bigger brakes............
                      • M-technik-3
                        • 18946
                        Pad's look like they are hardly covering half the rotor. Lets see more of the Ls swap.
                        • NC325iC
                          • Mar 2004
                          • 6565
                          if i was doin an LS swap i dont think id cheap out with a junkyard BBK, pretty sure id go with a massive kit.
                          are the piston bores matched well with the master cylinder?
                          just wanna make sure you did your calculations
                          • xwill112x
                            • Jan 2009
                            • 4236
                            ^^ why when you can do something very similiar with rx7 brakes as well? i'd spend 40$ anyday over 1200$
                            • Fidhle007
                              I can fly, motherfucker
                              • Oct 2005
                              • 7209
                              Because it's not similar, it's a cheap alternative. You get what you pay for.
                              '89 325is S50 Track Montser
                              '04 X5 Daily/Tow Vehicle
                              http://www.avarestoration.com
                              http://www.myspace.com/brendanfiddle
                              Click here if you want to be my zombie slave...
                              http://www.youtube.com/user/Fidhle007
