So has anyone ever shattered there back window while removing the subframe? I shattered my back window on Sunday. Its in a million pieces. Oh, and yes the jack stands were on the OEM jack stand locations.
Rear Window Shatter While Removing Subframe
Randall Racing and Engineering
Acworth, Georgia, 30101
http://www.facebook.com/RandallRacingandEngineeringTags: None -
Wowsers. What were you doing? Shouldn't happen I don't think.
I am doing this... this weekend. Will try to be careful :)
Spontaneous rear windshield failure is not unknown. I'd bet yours was just getting ready to do that.2006 GMC Sierra 2500HD 4WD LBZ/Allison
2002 BMW M3 Alpinweiß/Black
1999 323i GTS2 Alpinweiß
1995 M3 Dakargelb/Black - S50B32/S6S420G/3.91
1990 325is Brilliantrot/Tan
1989 M3 Alpinweiß/Black
sigpicComment
I have a rear glass for sale if you need one.
The rear glass should no break that is some major flex if it does. I would check to see if your chassis is straight.
Keep us posted.Comment
Matt
Originally posted by slammin.e28guyI pack my CD player with asbestos. Those mother fuckers pay dearly for stealing my shit.Originally posted by kronustry whacking parts of the motor with a wrench while yelling "YOU WANT SUMMA DIS? HUH?"Originally posted by chadthestampedeThis is like a reverse build thread; it starts out nice and gets shitty.Comment
Im lucky I have a spare rear window from a parts car, however Its just more of a pain in the ass than I wanted to deal with right now. It just opens another bag of worms that Im not ready for such as I was planning to replace the headliner anyways but I wanted to fix my leaky sunroof first/do the electric sunroof modification.
If anyone wants a complete rear subframe set up let me know. I built the rear subframe from my parts car and then rolled it right up and bolted it in. The swap itself took about 2 hours. The build of the spare subframe took about 8 hours. All new rubber bushings!Randall Racing and Engineering
http://www.facebook.com/RandallRacingandEngineeringComment
The usual reason for the rear window breaking is a hot spot while the defogger grid is on -- perhaps combined with the defogger switch jamming on.
Otherwise the rubber gasket should be isolating the rear window much better than the rigid adhesive on more modern cars. (By the time the e30 was designed most unibody designs had already switched to bonded-in windows to increase rigidity.)Comment
Was your statement above stating that this damage had been done by using the rear defrost over a period of time?The usual reason for the rear window breaking is a hot spot while the defogger grid is on -- perhaps combined with the defogger switch jamming on.
The battery was disconnected because I am also in the middle of an e to i engine swap.Randall Racing and Engineering
I've had two of 'em blow for no apparent reason...
Note to self. Make sure you install the new rear sway bar endlinks while the rear subframe is out of the car.
What a joke. It took more time to install rear sway bar endlinks than to drop the hole rear subframe!!
Save your self heartache. Its really not worth it!Randall Racing and Engineering
