WTF?! i just found somethingwierd on my subframe...
  • T La
    • Dec 2009
    • 190
    bondo.. or SOMEthing where the top of the subframe pin should be.... has anyone ever encountered this before? or have any suggestions on how to get the pin out if the top of it isn't even there?
    the other side to...
  • Dj Buttchug
    • Jun 2010
    • 7688
    looks pretty factory to me...
    Turbo M42 Build Thread :Here
    Ig:ryno_pzk
    I like the tuna here.
    Originally posted by lambo
    • BimmerTim
      • Oct 2007
      • 613
      It's just a hole plug. Pry it off.
      1988 Bronzitbeige Metallic 325e 2-door S50 turbo (OO=( )=OO)
      2008 VW Rabbit
      1991 Audi 200 20vtq Wagon
      • T La
        • Dec 2009
        • 190
        i was under the impression that this was supposed to be the head of a pin-type bolt which you are supposed to whack out from the bottom... am i incorrect?
        • BimmerTim
          • Oct 2007
          • 613
          Yeah, it's under the cap. Pry it off.
          2008 VW Rabbit
          • george graves
            • 20003
            Hit the bolt from the bottom. It'll pop right out when you are doing the subframe.
            In other words - You don't pull that bolt out from the top.
            Originally posted by Matt-B
            • T La
              • Dec 2009
              • 190
              okay then i must not have been giving it enough force, from the DIY i was reading it looked like the pin should've already been sticking out of the top
              • T La
                • Dec 2009
                • 190
                damn misleading DIYs ....
                • george graves
                  • 20003
                  Nope. That pic is of it pushed up and resting on the splines. If you were to turn it a few degrees it would drop back into the hole as soon as the splines line up.
                  • T La
                    • Dec 2009
                    • 190
                    well now i just feel silly.
                    thanks guys
                    • george graves
                      • 20003
                      We've all been there. Trust me.
                      • E30Idea
                        • Mar 2007
                        • 2196
                        Very true, but this is the first thread in awhile that any OP has not been flamed for asking a standard question that we forget can be a "life or death" feeling to a newly born DIY'er
                        Keep at it.
                        ** Lot's of M20 turbo parts for sale.**
                        Turn key track car.
                        http://www.r3vlimited.com/board/showthread.php?t=222066
                        • T La
                          • Dec 2009
                          • 190
                          Keep at it.
                          apparently i'm not the first one to have that feeling hahhaa. thanks again.
                          • T La
                            • Dec 2009
                            • 190
                            okay guys, i just got the pins out, but now the subframe won't actually drop out; are there any tricks or techniques for physically dropping it out? it seems like it's getting stuck on the bushings...
                            • phenryiv1
                              • Jul 2009
                              • 3246
                              Prybar...carefully.
                              Patrick Henry
