help with CAB install
  • NC325iC
    • Mar 2004
    • 6565
    alright ive had them pressed into the lolipops (stock nonM rubber)
    its absolutely impossible to get them onto the arms now
    how do i do it
    • 34844
    hot water with dish soap (let them soak, keep them wet and SOAPY), a socket that will fit over the end of the control arm, and a dead blow hammer.. :)
    it's messy, but it works..
    • kencopperwheat
      King of Kegstands
      • 14396
      soapy water didnt do shit for me. I used white lithium grease.
      Originally posted by Gruelius
      • NickP
        • 257
        I wouldn't use lithium grease - it doesn't evaporate. This could lead to the bushing binding to a position on the control arm where there's some preload.
        I've found that some dish washing soap and hot water does the trick. You just have to get the bushing barely started and it should slide on with one or two blows of a hammer on a deep socket on the bushing.
        If the control arm is being reused its also a good idea to clean up the end with some fine sand paper.
        • kencopperwheat
          King of Kegstands
          • 14396
          If it doesn't evaportate how will it bind? And if it does evaporate, how will it bind in a preload? If it decides to bind when the control arm is hanging there after I take my car off of a jump?
          • NC325iC
            • Mar 2004
            • 6565
            either way a big hammer didnt do shit we finally got them on
            long threaded bar bent in half through the first hole. put some square tubing with holes in it and kept tightening the bolts till it was on good
            • RCWells
              • 3589
              NOOOO, you needed a BIG FUCKING HAMMER!! Not a big hammer. :roll:
              [THE 501 club - Founding Member]
              • NickP
                • 257
                Sorry if I wasn't blatantly obvious...
                Unlike soapy water lithium grease won't allow the control arm bushing to set to the control arm in a reasonable amount of time before you drive the car - e.g. 24 hours.
                I'm sure the lithium grease will eventually get absorbed by the rubber / burnt up - I don't know. If the bushing binds as the suspension travels which is likely - you now have some preload on your control arm bushing.
                This isn't anything new and is why most writeups / Bentley tell you to get the car off jackstands and let it stand for awhile before taking it for a drive.
