anyone install zerk fittings on rtab
  • chasiubao
    • Mar 2006
    • 335
    anyone out there put on zerk fittings in their rear trailing arms when using the poly rtabs? I may do this to try and get the squeakies out...
  • CorvallisBMW
    Long Schlong Longhammer
    • 13039
    Not a bad idea...
    1. Locate them in an easy-to-reach spot
    2. Drill hole through metal case and bushing
    3. Install zerk
    4. ...
    5. Profit! (and no more squeeks)
    You'd really have to do it right though to make sure grease was actually distributed to the whole length of the bushing and didn't just end up getting pushed in to one part and then out the end.
    • StereoInstaller1
      GAS
      • 22679
      Does FWD GM count? I had one hell of a time doing it. Ended up notching the subframe and all on my old GrandAm.
      When I do the adjustable setup, I am most certainly gonna do it. 120,000 miles on that GM would have sucked ass if it squeaked like the E30.
      Closing SOON!
      Thanks for 10 years of fun!
      • dude8383
        • Jan 2005
        • 10387
        I've been thinking about doing this for years... HAHA and I still haven't done it.
          The trick would be be in getting grease to the inner sleeve, since that is where the motion occurs and the squeaks come from.
          • AbsorbantNut
            Non faccio funzionare questa merda
            • Jun 2010
            • 2491
            I also wondered if anybody here had done something like this, it sounds like a good idea to cut down on noise
            '73 2002 m20 turbo [sold] '87 rat rod 325is [couch modded] '91 vert [daily] '88 325is [spec build v1] '84 325 [spec build v2] '99 323i vert [sold]
            • dude8383
              • Jan 2005
              • 10387
              That's actually the main reason why I've been dragging my feet with this. I'm concerned about damaging the bushing.
              • gearheadE30
                • Jun 2007
                • 3734
                I did it on the front control arm bushings, but not on the back yet. I'm either going to be replacing the rtabs with stock rubber ones soon or maybe replacing the poly. I have a hunch that the thunk coming from my rear end when changing directions (i.e. reverse to forward) is being caused by worn sleeves in the rtabs...
                Project M42 Turbo
                • dude8383
                  • Jan 2005
                  • 10387
                  Can we get a picture of your control arm bushings?
                    • 34839
                    I'm still not getting squeaks after 8 years on the same poly RTABs. I don't get it..
