fucken brakes broken bitch bolt! help
  • moatilliatta
    • 6151
    <p><img src="http://www.r3vlimited.com/board/images/smilies/icon_evil.gif" border="0" alt="" title="Evil or Very Mad" smilieid="203" class="inlineimg" /> <img src="http://www.r3vlimited.com/board/images/smilies/icon_evil.gif" border="0" alt="" title="Evil or Very Mad" smilieid="203" class="inlineimg" /> <img src="http://www.r3vlimited.com/board/images/smilies/icon_evil.gif" border="0" alt="" title="Evil or Very Mad" smilieid="203" class="inlineimg" /> </p>
    <p>Scenario...</p>
    <p>my left front brake started to hum while breaking. (light breaking). so i thougt it may be time for pads. the surface of the disk was smooth and not needing turned or anything. anyways, i took off the wheel and noticed that the allen bolt that holds one the disk has broken off. i thought that maybe the cause of humming. (since there was still life left on the pads) i drilled threw that bolt and used pb plaster and let it set for an hour or so. then i hammerd a tork head into there and tried to break it out. i must of had a piece of shit one because that broke off in there. and im thinking is this allen bolt in the hole tighten really nessary?</p>
    <p> my question is, is it?</p>
    <p>&nbsp;</p>
    <p>any sugustions?</p>
    <p>&nbsp;</p>
    <p>thanks-zach</p>
    ________
    K100RS
    @Zakspeed_US
  • moatilliatta
    • 6151
    <p>yeahh i think the bolt is inportain. or else it woulnt be there. but i could be wrong.</p>
    ________
    Suzuki RM100
    @Zakspeed_US
    • rs4pro3
      • 5808
      There is a small allen bolt that holds the rotor onto the hub, it can be left out but makes it a pain to get the rotor, wheel, and hub all lined back up and the lugbolts threaded back in.
      85 325e 2.7 ITB'd stroker
      • moatilliatta
        • 6151
        <p>thanks man</p>
        <p>[/quote]</p>
        ________
        vapir air one vaporizer
        @Zakspeed_US
        • ///M Powered
          • Jan 2004
          • 1109
          There was a discussion earlier about how important the set screw is , a lot of people don't use them, a lot of people do. Make life easier and just keep them :P
          • emi
            • Jun 2005
            • 80
            oh man... i broke the upper timing belt tensioner bolt, then a drill bit, and an easy out bit. Trust me... your problem is eeeeaaasy. Anyway, if you can't get the drilled out with a regular drill, get a carbide bit, they'll chew through anything. Just don't break one of those.. My girlfriend's dad is a machinist, and he was able to make a couple. I don't think they sell that stuff in stores, maybe a machine shop can hook you up.
            • Addissimo
              • Mar 2004
              • 1820
              That happened to me when I was working on bimmerphile's car- Take the closest sized bit to the inner thread diameter you can get. I think I took a couple of the hub threads with me, but I got the bolt out and a new one screws in fine.
              -Addis
              Doing something M50 related? -> http://www.addissimo.com
              On Myspace? ->http://groups.myspace.com/r3vlimited
              BF2142 SN = BillyGoose
