IE BBK installed, finally :)
  • fporro
    • 1859
    Schomething like that :)
    • E30_boy
      • 226
      Are those BBS RS 003? I am looking at this BBK from IE and want to make sure it will fit behind my BBS RS 003's
      • yahh
        • Aug 2012
        • 800
        In for answer.
        s50 86 325e Project
        S50 - BBS - Recaro - BC Coilovers - Morimoto H1 Retrofit
        Feedback Thread
        • fporro
          • 1859
          yes they are 003's 16x7 et25, you'll need spacers, at least 6mm's for bolts not to hit front calipers.
          here's a better pic, there's 2 x 3mm spacers in there, eventually went with 15mm H&R hub centric units... http://www.bimmerfest.com/forums/album.php?albumid=7555
          fronts
          rears
          • yahh
            • Aug 2012
            • 800
            Thanks for the quick reply! That would put me at 16x8.5 et 0 with the spacers. How much stopping difference do you feel?
            Sent from my SAMSUNG-SGH-I317 using Tapatalk
            s50 86 325e Project
            Feedback Thread
            • fporro
              • 1859
              You're welcome, stopping power it's right on, get a 25mm M/C from a 750i or e30 m3 and a bias valve for them,
              also steel lines all around including clutch.
              here's Hartges monoblock 16x7 et24,
              I think just about every multi piece 16 inch wheel will hit front calipers as is the back of bolts that contact it.
              just picked up some SSR Mesh 16x7 et24 on 4x100's and they do hit as well.
              here's 15mm H&R spacer i use, both front and rear to keep things balanced, rears do not need it... http://www.bimmerfest.com/forums/album.php?albumid=4178
              • E30_boy
                • 226
                Thanks for the excellent pictures and reply "fporro"! "Yahh" are doing wide lips on your 003's also? I am going to do 8.5 front and 9 in the rear. I don't want to run a spacer with this set up. 8.5 et6 is going to be super flush as it is.
                • yahh
                  • Aug 2012
                  • 800
                  Yup I already have them done. Check my thread for how they fit.
                  s50 86 325e Project
                  Feedback Thread
