My brake lining light is comming on
  • cobraken
    • Oct 2004
    • 674
    I dont know if its because the fronts are bad or if its the rear brakes. The car has 225k. Since i dont know how well the car was taken care off in the past should i just replace verything? or just fix the part thats bad? How can i tell wich brakes are making the light come on?
    Randall Racing and Engineering
    Acworth, Georgia, 30101
    http://www.facebook.com/RandallRacingandEngineering
  • DanGillan
    • Mar 2004
    • 4061
    take the bulb out of the cluster, do pads and rotors, maintain your car on your own schedule.
    Dan
    • cobraken
      • Oct 2004
      • 674
      haha, but i want to be safe. I like having all the idiot lights. Its good for whenever girls drive the car.
      • cthulu703
        • Oct 2004
        • 288
        The sensor is closed for on, so if you go around and disconnect the front and rears in turn and check for the idiot light, it will let you know which ones are bad. Or better yet just look into the calipers from the top and determine which ones are running out of pad.
        • Digitalwave
          is a poseur
          • 6292
          It's not like they are going to pull over and change the brake pads right when the light comes on.
          RISING EDGE
          • AndrewBird
            The Mad Scientist
            • 11898
            Ignore the light and check the brakes every time you change you oil. I ASSUME you change your own oil, and if you don't, you should. There are many things that should also be checked about every oil change like brakes, brake fluid levels, transmission fluid levels, check for loose/broken/bent parts, etc... Doing basic maintenance on your car is the best thing you can do for it. If you just let some guy at a shop do it, you don't know what condition your car is actually in.
            • Addissimo
              • Mar 2004
              • 1820
              Word-
              They'll just freak out and ask whats going on.... Unless of course those girls you were talking about are actually you....
              Doing something M50 related? -> http://www.addissimo.com
              On Myspace? ->http://groups.myspace.com/r3vlimited
              BF2142 SN = BillyGoose
              • cobraken
                • Oct 2004
                • 674
                Word-
                Nope not me, I HAD a girl friend and she was driving it for about a month while her car was getting fixed.
