will this master cylinder fit my car?
  • hooken m
    • 1537
    this is the one that i want to buy. my main concern is if it will properly fit on my 87 325. im not 100% sure if that master cylinder is identical to the e30 m3 master cylinder. and if so, what modifications must be done in order for it to fit on my car. i heard you have to slightly bend a hard brake line, but thats it. thanks for the help as always
    Originally posted by evandael
    a car is a car. call it a dildo, i'd still drive the hell out of it.
  • Bmjpv
    • Mar 2007
    • 561
    I think m3 e30 are 23mm, that is a 25 which came off the bigger cars. It will bolt up but pedal pressure might be very hard. some like it, some don't. I used that master on my 88'Is 24v but I'm running M3 e30 brakes all around and really like the way it worked out for me. Joe
    • hoveringuy
      • Dec 2005
      • 2715
      With stock e30 calipers it was firm. It's a matter of preference.
      • Adrian_Visser
        • Jun 2006
        • 2823
        So that one fits with the stock booster? I thought that the 25mm MC would only fit on an IX booster.
        '89 Alpine S52 with goodies
        • 2002maniac
          • 4260
          Yes it will fit.
          • Holland
            • Nov 2008
            • 7202
            So wait, it's the same for ABS and non ABS cars? I want to put one of these on an early 318i, I did a rear disc conversion and the pedal is too soft for my liking.
            Originally posted by DEV0 E30
            • 2002maniac
              • 4260
              You'll need a tee for the front brake lines as mc on abs equipped cars have only 2 outlets.
