Just had offset control arm bushings installed....
  • etajohn
    • May 2005
    • 79
    I had this done at a well recommended shop and they say it doesn't alter the alighnment. But just looking at it makes me think it has to add toe in and I need it checked. I questioned them on this and they say they do it all the time with no problems. So what gives?
    Thanks.
  • arsevader
    • May 2005
    • 1025
    Re: Just had offset control arm bushings installed....
    Thanks.
    Offset bushings just alter caster, they do nothing for toe.
    James
    • rs4pro3
      • 5808
      some times it can change the alignement and other times no, Does the car still trac straight? I changed my CAB and the alignment was still good.
      85 325e 2.7 ITB'd stroker
      • alex
        • 2024
        They do alter toe as well. You need to have your toe set. Unless it was out of wack before and the mod brought it back to spec.
        • etajohn
          • May 2005
          • 79
          Thank you Alex. I thought so. Yes, it tracks straight ahead but but that isn't the point. Too much toe in isn't going to make it wander or pull to one side. It is going to make the steering stiffer and wear out tires.
          • M42Technik
            • 9781
            Do your alignment now.
            My toe after the installation was around 1.6... which is retarted large. Should be as close to zero as possible...
            Reminiscing...
              • 34839
              that all depends on driver preference and what you are doing with the car. for me, toe out is best.
              • alex
                • 2024
                1.6 what?
                Toe is measured in units of distance, for example mm or inches. Factory spec is few mm toe-in. For racing anything between 0 and very slight toe-out is preferred, how much depends on driver preference as Chris said.
                • erik325i
                  • Jan 2005
                  • 3567
                  Can you educate me as to why toe-out is better for racing and why toe-in is better for daily driving?
                  • ed94r
                    • Mar 2004
                    • 382
                    Front toe out sharpens corner turn-in response at the expense of tire wear and straight line speed.
                    0 front toe aids in straight line speed/tire wear at the expense of turn-in sharpness.
                    Front toe-in just sucks.
                    Ed
                    1988 E30/S50...now with S52; Track
                    1994 Miata R; ES Solo2
                    1998 Lexus LX470; Wife (Slee'd anyway)
                    2002 BMW 530i; A+ Commuter
                    2002 BMW 325iT; Sport/Premium 5-speed
                    2011 21' EconoTrailer
                    • erik325i
                      • Jan 2005
                      • 3567
                      Ed
                      So, why would factory spec be a few mm toe-in, as Alex stated?
                      • arsevader
                        • May 2005
                        • 1025
                        Ed
                        Straight line stability at speed.
                        James
                          • 34839
                          Ed
                          James
                          and lower tire wear, but if you have a couple degrees of negative camber/you drive your car hard your tire wear is going to be screwed anyway.. may as well have responsive handling. ;)
                          • trent
                            Thanks.
                            James
                            As others said, completely wrong.
                            I have always ran 1/16 toe in front and rear. I only find toe-out helpful for autocross situations.
                            • arsevader
                              • May 2005
                              • 1025
                              Thanks.
                              James
                              I'll take peoples word for it but I still fail to see how offset bushings are going to alter toe. The bushing pushes the bottom of the strut forward thereby increasing caster. Unless you change the length of your tie rods, how does your toe change?
                              Just want to know.
                              James
